Thread: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
Results 1 to 20 of 22
  1. #1 Re: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    I just pulled the DRL fuse and unplugged the connector right above the parking break. This module is the part that clicks when you remove the DRL fuse. Remove the plug and you now have manual lights and no clicking.
    The DRL fuse is the one in the fuse box right?
    and where is that plug located exactly? do i need to remove any plastic trims?
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  2. #2 Re: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
    Houston
    Quote Originally Posted by biggt View Post
    Yes, the DRL in the glove box, fuse box. No plastic trims need to be removed, just that carpet board piece that attaches to the "knee basher", if your car still has it.
    The module is on the driver side and it will have two plugs. Unplug the one on the right. If you look in the picture, that spring is the parking brake spring. And that larger module to the right, I believe is the Body Control Module. After you remove the DRL fuse, you should start hearing the clicking (if your car is on) and that will lead you to this module. In this picture the 2nd plug is already removed.
  1. headlight problem 2002 se please help
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 04-06-2012, 01:02 PM
  2. How to safely remove headlight cover?
    By Juanmiguel in forum Visual/Body Modifications
    Last Post: 12-15-2009, 03:47 PM
  3. how do i remove the logo off my headlight covers
    By NEONNIGHT34609 in forum Visual/Body Modifications
    Last Post: 01-31-2009, 12:47 PM
  4. drls or auto headlight?
    By crywolf in forum General Tech Discussion
    Last Post: 11-25-2008, 11:56 AM
