Yes, the DRL in the glove box, fuse box. No plastic trims need to be removed, just that carpet board piece that attaches to the "knee basher", if your car still has it.
The module is on the driver side and it will have two plugs. Unplug the one on the right. If you look in the picture, that spring is the parking brake spring. And that larger module to the right, I believe is the Body Control Module. After you remove the DRL fuse, you should start hearing the clicking (if your car is on) and that will lead you to this module. In this picture the 2nd plug is already removed.
