Thread: New stereo install for 2002 GTP with Bose
Results 1 to 20 of 38
  1. #1 New stereo install for 2002 GTP with Bose
    Donating Users smitz327's Avatar
    Oct 2012
    Illinois
    Hey guys, I am planning on buying a new Kenwood BT852HD for the 2002 black GTP with the Bose system. I plan on just using the Bose amp that is in the trunk and don't care about the door chimes or the On Star because it doesn't work anyways. I am not in to blowing my ear drums out so it doesn't have to be real loud. Do I need anything special besides the install kit or the steering wheel control adaptor? Also another note, when playing the stereo that is in it now, I am noticing a whining noise coming over the speakers, is there a fix for that or is that normal for the Bose system?
  2. #2 Re: New stereo install for 2002 GTP with Bose
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    if it has a aftermarket in there with no noise canceler on it then it will have a whin when running my double din did that and i installed a noise canceler and it went away on both amps the componet amp and the sub amp
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  3. #3 Re: New stereo install for 2002 GTP with Bose
    Oct 2012
    Illinois
    Everything is original in the car, has the standard Delco stereo in it with the Bose speakers and Bose amp in the back. I remember a long time ago when I installed a new stereo in a car with amp and it had that noise and what I did was install a capacitor in the wiring but I cannot remember how to do that.
  4. #4 Re: New stereo install for 2002 GTP with Bose
    Feb 2009
    Virginia
    Noise canceler's are not necessary if the head unit is grounded properly. Noise/Alt. Whine/Ground noise is usually cross talk between the DIFFERENCE OF TWO GROUNDS. Two ground sources CAN interact. However, the usual cause is insufficient surface area or mass with the original ground. i.e. grounding to a thin piece of sheet metal, using a bolt w/o a washer, not scraping paint to allow metal on metal contact, lead crimp on wire isn't tight enough, etc. etc...poor contact is the issue.
    If that's not the issue perhaps you're pulling more current and the grounding wire isn't sufficient? Can you describe how you connected the power and ground? I suspect a bad connection.
    If you have the option of turning off the internal amplifier on the new HU try that and see if you still have the noise in the speakers. You have to identify the source of the grounding issue before you point fingers.
    My GMOS 100 wire harness was the culprit in my first install.
    EDIT: Just remembered something else...double check the voltage turn on for the Bose Amp. I think it's only 5V. Make certain you have a resistor or circuit in the wire harness that changes your amp turn on voltage down from 12V
    11 is louder than 10!
  5. #5 Re: New stereo install for 2002 GTP with Bose
    Oct 2012
    Illinois
    I have not even touched the stereo yet. I am buying a new head unit soon but have noticed the whining noise in the speakers for sometime with the Bose system that is installed now which is original. I do not listen to the music loud either and have noticed the noise even with the volume down all the way. Could it possibly be the Bose Amp causing that which is in the trunk? Since I will be replacing the HU, is there anything special I should know about hooking it to the Bose?
  6. #6 Re: New stereo install for 2002 GTP with Bose
    Feb 2009
    Virginia
    Hrmmm. If you could unplug the source(HU) and keep power to the amp then you'd know if it was the amplifier making the noise.
  7. #7 Re: New stereo install for 2002 GTP with Bose
    Topeka, KS
    Interesting stuff about the grounds. I'm going to have to reground my cig lighter now. When i charge my phone i get the whine when it running audio from it. Simple fix if that's all it takes...
    Carry on. Good info here I800!
  8. #8 Re: New stereo install for 2002 GTP with Bose
    Yoga city
    did we go through the classice wires pinched, power/remote wires running over rcas?
  9. #9 Re: New stereo install for 2002 GTP with Bose
    Oct 2012
    Illinois
    Maybe I will just to have to wait till I get the new HU installed, I will know for sure then. Replacing the amp if needed won't be a problem or I may just bypass it and just use the amp in the stereo only
  10. #10 Re: New stereo install for 2002 GTP with Bose
    Yoga city
    i will telll you right now i chased down a hum in my friends car for almost 2 months now, he swore the deck wasnt the issue. he replaced everything, Amps, wires, batts, and i even reran all new electrical circuit for just the stereo. ends up its the faulty deck.
  11. #11 Re: New stereo install for 2002 GTP with Bose
    Oct 2012
    Illinois
    Possibly is the problem, Doesn't the Delco stereo come with a amp built in to it? If so, that definitely could be the issue. I don't know but I remember the stereos back in the late 80's and 90's and they were notorious for that. People had to put capacitors on the ground wire to stop the whining. Looking forward to replacing the stereo, The system is nice but I like the idea of having Bluetooth calling and streaming music. One thing to keep in mind, if you ever buy a new HU, make sure you get one with an external microphone. The ones with built in mic pick up to much road noise
  12. #12 Re: New stereo install for 2002 GTP with Bose
    Yoga city
    just run new grounds and power, cleared up issue with diff deck in.
  13. #13 Re: New stereo install for 2002 GTP with Bose
    Feb 2009
    Virginia
    Easy way to isolate the deck is to use a 3.5mm to RCA. Play your ipod or something similar into your amps. That will isolate the radio. If you still hear it then it's in your amplifiers.
  14. #14 Re: New stereo install for 2002 GTP with Bose
    Dec 2012
    Hawai'i
    Um everyone he has a stock system... Lol. Not everyone but a lot are posting about aftermarket systems... It says in the original post stock everything. I say replace the deck and go from there
  15. #15 Re: New stereo install for 2002 GTP with Bose
    Feb 2009
    Virginia
    I just went and looked. oops. Thought he had the RCA wire harness from the factory
    Keep us updated.
  16. #16 Re: New stereo install for 2002 GTP with Bose
    Oct 2012
    Illinois
    Ok, getting around to buying the Kenwood system for the car and Crutchfield says I need a PAC SOEM-4 which is a Universal 4-channel line output converter and from seeing the reviews on Crutchfield about the product is that it is a waist of money and I do not need. Anyone have any idea if I need this or can I wire up the Bose amp directly?
  17. #17 Re: New stereo install for 2002 GTP with Bose
    Oct 2012
    Illinois
    Quote Originally Posted by 00grandprixgtp View Post
    You installed a double din in your Pontiac Grand Prix? Seen some photos before but you have any with your double din installed?
  18. #18 Re: New stereo install for 2002 GTP with Bose
    SE Level Member RAGEN's Avatar
    Feb 2013
    SE
    My 2000 came with the factory Bose. I now have a Sony double din with navi and the Bose system with no problems.
  19. #19 Re: New stereo install for 2002 GTP with Bose
    Oct 2012
    Illinois
    Do you have any photos? Was it a pain getting it installed? I have been thinking double din but not sure how it would look
  20. #20 Re: New stereo install for 2002 GTP with Bose
    Feb 2013
    SE
    Having trouble uploading pics. Files are to large.
  1. 01 GTP with bose and OnStar replace stereo without expensive wiring harness
    By Draco in forum Audio, Security & Visual Electronics
    Last Post: 03-10-2013, 12:05 PM
  2. Stock Bose Stereo Replacement
    By jeepers in forum Audio, Security & Visual Electronics
    Last Post: 04-03-2011, 05:19 PM
  3. need help on how to put amp and subs in along with a bose stereo
    By rh5385 in forum Audio, Security & Visual Electronics
    Last Post: 09-06-2009, 12:15 PM
  4. Bose stereo problem
    By jiggar1964 in forum Audio, Security & Visual Electronics
    Last Post: 11-21-2008, 05:02 PM
