Thread: New stereo install for 2002 GTP with Bose
Results 1 to 20 of 38
  1. #1 Re: New stereo install for 2002 GTP with Bose
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    if it has a aftermarket in there with no noise canceler on it then it will have a whin when running my double din did that and i installed a noise canceler and it went away on both amps the componet amp and the sub amp
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  2. #2 Re: New stereo install for 2002 GTP with Bose
    Donating Users smitz327's Avatar
    Oct 2012
    Illinois
    Quote Originally Posted by 00grandprixgtp View Post
    You installed a double din in your Pontiac Grand Prix? Seen some photos before but you have any with your double din installed?
  1. 01 GTP with bose and OnStar replace stereo without expensive wiring harness
    By Draco in forum Audio, Security & Visual Electronics
    Last Post: 03-10-2013, 12:05 PM
  2. Stock Bose Stereo Replacement
    By jeepers in forum Audio, Security & Visual Electronics
    Last Post: 04-03-2011, 05:19 PM
  3. need help on how to put amp and subs in along with a bose stereo
    By rh5385 in forum Audio, Security & Visual Electronics
    Last Post: 09-06-2009, 12:15 PM
  4. Bose stereo problem
    By jiggar1964 in forum Audio, Security & Visual Electronics
    Last Post: 11-21-2008, 05:02 PM
