I like the looks of the halos and projectors but which style of headlights has the best light projection
I do a lot of nighttime driving
one word. retrofit
If you do lots of nighttime driving (like myself) skip spending the $200ish on the ebay projectors (the light output is worse than stock headlights) and retrofit your own.
Yes, it will cost more (Around $320 all together for mine) but the light is absolutely amazing. You will not regret it. From start to finish, it took me less than 10hours, my first time.
stock silverstar ultras
My potato has better output
Those aren't aimed correctly. The steps in the lights are wrong. You'd get a wider beam if they were aimed right. The problem with those is with them being one solid piece. You might get them aimed right but they'll look all jacked up I guarantee it.
*EDIT* and to answer the original question... retrofits and if you don't want to spend the money just do hids in the stock housings. I've done 2 retrofits now though and they really aren't that hard. Do a ton of reading and looking at pictures beforehand and you'll be fine.
the people that say these headlights sucks worse than stock are complete IDIOTS. ran stock couldnt see people on the side of the road until I almost ran them over. ran hids in oem housing, run sonars now. Sonar are more FOCUSED than HID in oem. Visually Id say hid and hid projector are the same, prob the projector is better because of the more focused beam and not all over. Love mine, wont change it
Uploaded with ImageShack.us
retros
