Thread: Which style of headlights has the best light projection
Results 1 to 20 of 29
  1. #1 Which style of headlights has the best light projection
    SE Level Member JimSWylie's Avatar
    May 2013
    Newport, WA
    I like the looks of the halos and projectors but which style of headlights has the best light projection
    I do a lot of nighttime driving
  2. #2 Re: Which style of headlights has the best light projection
    antioch ill
    one word. retrofit
  3. #3 Re: Which style of headlights has the best light projection
    Dec 2011
    Philadelphia, PA
    do not do projectors so yea retro fit
    AEM bruteforce intake
    Diablo 93 Octane tune
  4. #4 Re: Which style of headlights has the best light projection
    Florida
    If you do lots of nighttime driving (like myself) skip spending the $200ish on the ebay projectors (the light output is worse than stock headlights) and retrofit your own.
    Yes, it will cost more (Around $320 all together for mine) but the light is absolutely amazing. You will not regret it. From start to finish, it took me less than 10hours, my first time.
  5. #5 Re: Which style of headlights has the best light projection
    May 2013
    Newport, WA
    Thanks for the information
  6. #6 Re: Which style of headlights has the best light projection
    Banned
    Jan 2013
    Colorado
    stock silverstar ultras
  7. #7 Re: Which style of headlights has the best light projection
    Jan 2012
    Canada
    I have no problems with My spyders and they are a huge upgrade over stock.
    2001 GTP Special Edition - 3.29's built tranny, Coilovers with agx struts, 04+ seats, 18" Eagle 077's, Ported heads, ported blower, pacesetters, 3.4"
    2004 BMW 325CI with the sport package and the correct amount of pedals.
  8. #8 Re: Which style of headlights has the best light projection
    Florida
    Quick video on my phone. Lights off
    HID fogs in stock housin
    then low beams (Mini H1's, 5000k) and fogs,
    then high beams (Mini H1's 5000k with shield lifted)
    and back off.
    I'll try and get a better video, but the high beams are amazing on the country roads around here.
  9. #9 Re: Which style of headlights has the best light projection
    The Boss Iceman6669's Avatar
    Jun 2011
    Quote Originally Posted by killerspeed101 View Post
    That is honestly prolly worse then my HIDs in black crystals....
    2011 F-150 Yote powered
  10. #10 Re: Which style of headlights has the best light projection
    Jan 2012
    Canada
    Quote Originally Posted by Iceman6669 View Post
    How so?
    The s3 cam sucks while trying to do night pictures of light output
  11. #11 Re: Which style of headlights has the best light projection
    antioch ill
    My potato has better output
  12. #12 Re: Which style of headlights has the best light projection
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Those aren't aimed correctly. The steps in the lights are wrong. You'd get a wider beam if they were aimed right. The problem with those is with them being one solid piece. You might get them aimed right but they'll look all jacked up I guarantee it.
    *EDIT* and to answer the original question... retrofits and if you don't want to spend the money just do hids in the stock housings. I've done 2 retrofits now though and they really aren't that hard. Do a ton of reading and looking at pictures beforehand and you'll be fine.
  13. #13 Re: Which style of headlights has the best light projection
    Jan 2012
    Canada
    Quote Originally Posted by SomeDudeAtHome View Post
    i know, my car was backed into and the light took the hit, broke the bracket and i zip tied them up and havent cared to aim them till i fix the foglight relay.
  14. #14 Re: Which style of headlights has the best light projection
    Antioch, IL
    the people that say these headlights sucks worse than stock are complete IDIOTS. ran stock couldnt see people on the side of the road until I almost ran them over. ran hids in oem housing, run sonars now. Sonar are more FOCUSED than HID in oem. Visually Id say hid and hid projector are the same, prob the projector is better because of the more focused beam and not all over. Love mine, wont change it
    Uploaded with ImageShack.us
    2009 Challenger SRT8
    Expert at being gay.
  15. #15 Re: Which style of headlights has the best light projection
    May 2013
    Newport, WA
    Thanks for all the input and i will do so more research before i decide.
  16. #16 Re: Which style of headlights has the best light projection
    Jun 2011
    Defo on retro.
  17. #17 Re: Which style of headlights has the best light projection
    Never Never Land
    Retro or bust.
  18. #18 Re: Which style of headlights has the best light projection
    antioch ill
    retros
  19. #19 Re: Which style of headlights has the best light projection
    Never Never Land
    Woooo yea...get sum.
  20. #20 Re: Which style of headlights has the best light projection
    Antioch, IL
    sonar GET SUM
  1. 1995 GTP ABS light and headlights dimming
    By Adabow12 in forum Brakes/Suspension/Chassis
    Last Post: 08-05-2011, 07:36 AM
  2. Stock Style light replacements
    By Phyrstorm in forum Visual/Body Modifications
    Last Post: 07-24-2011, 02:12 PM
  3. Projector/halo headlights and tail light covers.
    By starscream5000 in forum 04+ Specifics
    Last Post: 12-13-2010, 09:34 AM
  4. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
