Thread: Higher wattage fog bulbs with 04+ housings
Results 1 to 3 of 3
  1. #1 Higher wattage fog bulbs with 04+ housings
    Pennsylvania, USA
    Has anyone with an 04+ Grand Prix used higher wattage bulbs in their stock fog light housings? I have 35 watt bulbs now but they're still not all that great. I'm not necessarily going for bright fogs or I'd get HID's, but even the 35 watt bulbs don't help as much in the fog or at night as I'd like them to.
    I feel like the wiring harness could take the wattage as it seems to be the same gauge as the headlight wiring, but I'm worried about melting the housings. I know that 97-03 housings can melt, and I've never seen any specifics on 04+ housings.
  2. #2 Re: Higher wattage fog bulbs with 04+ housings
    Omaha, NE
    Drill 2 small holes in the back of the housing towards the top so heat can escape and you should be fine.
  3. #3 Re: Higher wattage fog bulbs with 04+ housings
    Pennsylvania, USA
    Great and easy idea, I'll probably do that and even add those little elbow grommets just to ensure water doesn't get in, thanks!
  1. What gives the L36 Higher Compression?
    By BlackGT97 in forum General Tech Discussion
    Last Post: 04-10-2012, 09:52 PM
  2. Higher Than a Kite!
    By BoostenGTP in forum Visual/Body Modifications
    Last Post: 01-16-2011, 12:18 AM
  3. Bose amp wattage
    By bm127 in forum Introductions/Noob Questions
    Last Post: 10-25-2009, 09:11 PM
  4. Does anyone know the Wattage draw of the Stock headlight Bulbs?
    By Blacknight02GT in forum Off Topic Discussion
    Last Post: 06-26-2009, 11:33 AM
