Thread: How do I hook up a sub to the Bose system?
Results 1 to 20 of 21
  1. #1 Re: How do I hook up a sub to the Bose system?
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    Quote Originally Posted by Anthony Smith View Post
    I have a whole pile of aftermarket crap wired up to my stock Bose HU. 3 amps, sub, 6x9's plus a harwired MP3 line input. A line convertor wont work well unless you run it off the front speakers, the rears are low and high pass filtered in the bose amp so there isnt anywhere to get a full audio signal for a line convertor. The easiest way is to tap into the low level inputs from the HU to the bose amp, solder RCA leads to them. I get weird issues where when I first turn the car on my HU wont turn on unless I hit the window down button and stuff though....
    So I can still tap into the system in the trunk as long as I use the INPUT to the amp? I kinda figured I'd have to use the input instead of the output. I don't suppose anyone has a wiring schematic of the Bose amp?
  2. #2 Re: How do I hook up a sub to the Bose system?
    Apr 2011
    Vassar, Mi
    Yea pretty much, I dont remember the wire colors though. Also just to be clear, you dont hook the amp input wires to a line convertor. You just tap into them with RCA's and plug them into your aftermarket amp.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  3. #3 Re: How do I hook up a sub to the Bose system?
    Mar 2013
    Manitoba, Canada
    This is great news! Now I just have to find out which wires to tap. One of my life rules, "Always know what you are tapping."
  1. Adding an aux to bose system
    By Domenic Cianciola in forum Audio, Security & Visual Electronics
    Last Post: 10-13-2012, 12:10 AM
  2. bose sytem bad, looking at a new system
    By natethegreat in forum Audio, Security & Visual Electronics
    Last Post: 09-13-2011, 10:55 PM
  3. Bose sound system
    By mikesarebetter in forum Audio, Security & Visual Electronics
    Last Post: 12-03-2010, 11:08 PM
  4. Factory Amp In A 00 GP with Bose System
    By quickgt in forum Audio, Security & Visual Electronics
    Last Post: 05-25-2009, 11:19 AM
  5. How Can I Switch Out My BOSE System 4 My New Stuff
    By thagizzle213 in forum Audio, Security & Visual Electronics
    Last Post: 02-18-2009, 11:11 AM
