Thread: Factory Amp In A 00 GP with Bose System
Results 1 to 3 of 3
  1. #1 Factory Amp In A 00 GP with Bose System
    SE Level Member quickgt's Avatar
    Iowa
    im putting a new head unit in my GP. i have the full bose system with the factory amp. am i able to still run the bose system thru a new head unit? i will be getting the pioneer DEH-P6000UB thru Crutchfield.
    Pioneer DEH-P6000UB CD receiver at Crutchfield.com
    anyone have ideas? im going to be putting 2 12's in it soon as well but would still love to keep the bose system in working order with new head unit thanks!
  2. #2 Re: Factory Amp In A 00 GP with Bose System
    St. Louis Mo.
    Yes you are, but you have to "jump" the remote wire to the pinkish lookin wire to leads to the Bose amp. If you look at your factory wiring leading to the HU, you will see it off to the right, you need to splice into that to run the amp, or buy the correct coupler that will retain features. I opted for the cheaper connector, it was like $50 bucks less and I only lost the chimes that were of no importance and spliced the remote into that wire to activate the bose amp.
    James Shafer
    St. Louis MO
  3. #3 Re: Factory Amp In A 00 GP with Bose System
    Iowa
    this looks like what i need
    PAC OEM-2 Universal Factory Sound System Interface at Crutchfield.com
    but how does this thing work with aftermarket amps.
  1. Remove the factory bose amp in the trunk of my 02 GTP?
    By GTPjcoop in forum Audio, Security & Visual Electronics
    Last Post: 03-30-2009, 09:30 PM
  2. factory security system problem
    By TJs97 in forum Audio, Security & Visual Electronics
    Last Post: 03-14-2009, 12:44 AM
  3. How Can I Switch Out My BOSE System 4 My New Stuff
    By thagizzle213 in forum Audio, Security & Visual Electronics
    Last Post: 02-18-2009, 11:11 AM
  4. How to modify ZZP Gen I Stage II IC core/plates to work with factory PCV system
    By JEFFSGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2008, 12:53 AM
  5. Aftermarket headunit install on BOSE system??
    By FoSHO99 in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2008, 03:51 AM
