Thread: stock amp
Results 1 to 12 of 12
  1. #1 Re: stock amp
    SE Level Member kaosGP97's Avatar
    Oct 2008
    PA
    what like a 12 gauge wire or something
  2. #2 Re: stock amp
    no not 12 gauge, if you had the wiring diagram (which have not found yet) you could bypass the amp right at the source, allowing you to maintain all your existing speaker wiring. Otherwise, you should run brand new speaker wires (no finer than 20 gauge) to all the speakers and bypass all the existing wires. PITA i know but its just a fact of life. Tracking down the factory wiring is much more time consuming and frustrating in the end..Unless you had a wiring diagram (hint hint)
  3. #3 Re: stock amp
    Oct 2008
    PA
    Quote Originally Posted by _nick_ View Post
    thats what i was asking for i tried to find it on the net but no luck. im happy with the way it sounds as of now. i just wanted to see if i could get the stock amp to work, you know for poops and giggles. and what is PITA?
  4. #4 Re: stock amp
    pain in the ass
  5. #5 Re: stock amp
    SE Level Member bhrfpa11's Avatar
    Nov 2008
    Palmer, Alaska
    if you run an aftermarket stereo through the stock amp you are actually losing power. the stock amp produces less power than the amp in your deck right now.
  1. Stock gtp vs gt
    By keenan00gtp in forum Track Sessions and Kills
    Last Post: 10-30-2008, 12:50 PM
  2. stock air box
    By tod1d in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-01-2008, 09:00 AM
  3. 235/45/17/ or stock 225/45/17
    By 04CompG in forum Tires & Wheels
    Last Post: 05-23-2008, 11:36 AM
