Thread: Window Switches lights
Results 1 to 9 of 9
  1. #1 Window Switches lights
    Jan 2013
    Kansas
    Hello, is there anyway to make the driver side window switches light work? i think only the mirror switch lights up but the window lock, windows, and door lock swiches dont light up.. if i mess around with the switches a bit sometimes if im lucky they light up but i dont wanna to wear the switches out. Thanks!
  2. #2 Re: Window Switches lights
    Yoga city
    yeah chances are the bulbs are shot or solder has lost connection, there pretty easy to take apart and solder in an led. I did a full swap on my GTP. So it is totally posible if you have the time.
  3. #3 Re: Window Switches lights
    Jan 2013
    Kansas
    alright so how do you do that? i tried to take the door off the other day but i couldnt... it seem like it was stuck... then again i may have forgotten to take something off... just take the door off and remove the switch panel and solder them on? on a scale of 1-10 how diffucult is it?
  4. #4 Re: Window Switches lights
    Sep 2012
    Cedar Rapids, Iowa
    Woah you're working way too hard there. Take a flathead screwdriver and CAREFULLY remove the switch panel by prying it off. Take out the two plugs and the rest is fairly easy.
  5. #5 Re: Window Switches lights
    St. Louis
    Remove the switch panel from the BOTTOM of the panel (the part furthest away from the mirror adjustment). There is a metal clip at that end that holds the switch panel into the door. There is a plastic lip at the top edge that is notorious for breaking off if you get crazy with it. Then your switch panel will not snap back into place and just kinda sit there. Ask me how I know, lol....
  6. #6 Re: Window Switches lights
    Jan 2013
    Kansas
    MattF do you mean pry off the switch panel while the door is still attached or with the door panel off? and the other day i got the door off... broke some of the clips holding it in place though :/ and then i had to unscrew the switch panel from the door panel and i had it loose... i saw that it was clipped together but i didnt try to hard to remove them for fear of breaking them so i just left them on and put everything together again
  7. #7 Re: Window Switches lights
    Sep 2012
    Cedar Rapids, Iowa
    No, there is no need to remove the door to get at the switch panel. Take a flat head screwdriver, start at the bottom of the panel and carefully pry it up.
  8. #8 Re: Window Switches lights
    Jan 2013
    Kansas
    oh alright it makes more sence now, ill give it a try asap, just wish i woulda known this the other day lol but ill give it a try and get back to y'all
  9. #9 Re: Window Switches lights
    Jan 2013
    Kansas
    umm looking at it the other day there is something i forgot to mention... my cars an 2008, its not possible to pry it off like you guys said
  1. WTB: Door Light & Window Switches
    By nikkigpgt00 in forum Wanted To Buy - Parts
    Last Post: 02-12-2013, 06:54 AM
  2. New Window Switches
    By MattF in forum Audio, Security & Visual Electronics
    Last Post: 11-08-2012, 07:38 PM
  3. Lights in Window Switches
    By Joe in forum Audio, Security & Visual Electronics
    Last Post: 06-26-2009, 06:10 AM
