Thread: Sub/Amp Problems
Results 1 to 11 of 11
  1. #1 Re: Sub/Amp Problems
    Apr 2012
    North Dakota
    power output4 ohms 2x300 2 ohms 2x500 i have 4 and 8 gauge cables and i do not have a capacitor and i just measured the voltage drop and one side is 2.2 one is 3.3 also i found my ground what should i check about it. it isn't corroded or loose. i cant tell if i run big 3 two run to a tapped hole in the frame behind the seat just under the carpet which i believe are 8 gauge and then a 4 gauge i believe runs from battery or fuse box then splits into two to go into the amp
  1. maf problems... A G A I N!!
    By tc300 in forum General Tech Discussion
    Last Post: 05-20-2012, 11:25 PM
  2. ABS Problems
    By Logan541 in forum Brakes/Suspension/Chassis
    Last Post: 12-12-2011, 05:49 AM
  3. Having problems, please help
    By marccbr in forum General Tech Discussion
    Last Post: 10-25-2011, 09:39 PM
  4. 04 GT1 Problems (again)
    By KirkpatrickJTK in forum General Tech Discussion
    Last Post: 10-23-2011, 06:32 PM
  5. Pcm problems
    By Mje00GPGt in forum PCM Tuning
    Last Post: 09-27-2010, 07:35 PM
