Thread: gxp speedo problem
Results 21 to 40 of 49
  1. #1 Re: gxp speedo problem
    London Ont, Canada
    Don't you need a tch 2 to transfer milage to a swapped in DIC?
  2. #2 Re: gxp speedo problem
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Yes.
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  3. #3 Re: gxp speedo problem
    London Ont, Canada
    ok, thats what i meant by reprogram my 5 button DIC. now i just need access to one for that and the speedo lol
  4. #4 Re: gxp speedo problem
    GTP Level Member
    Sep 2011
    Motown
    so all i need to do is just get the vin re-learned and my speedo problem will be fixed?
    Quote Originally Posted by deadwoodspecial View Post
    On a side note, I do want to add that Classy is keeping it classy through all of this. The guy has a hell of a business ethic, and is doing everything possible to make this right. If anyone was, is, or has considered getting retro's, I HIGHLY recommend him. Good prices, and he backs his sh!t.
  5. #5 Re: gxp speedo problem
    Oct 2011
    MI
    It's an actual reprogram from SPS using a tech2 or MDI. It will teach it the vin number, options, etc.
    If that doesn't for some reason fix it there might be a problem with the cluster itself.
    I have seen different pin outs as well from different years
  6. #6 Re: gxp speedo problem
    GTP Level Member
    Sep 2011
    Motown
    Quote Originally Posted by rperry435 View Post
    You are going to have to help me with this language lol. Whats SPS? I will hopefully get this figured out tomorrow before I go back to school. Thanks
  7. #7 Re: gxp speedo problem
    Oct 2011
    MI
    Quote Originally Posted by Classy Pontiac View Post
    Service Programming System. It cost over $1k/yr for the subscription.
  8. #8 Re: gxp speedo problem
    London Ont, Canada
    Perry you seem to have the knowhow and access to the tool.. where in MI are you? provided its not outrages priced id pay to have ya hook me up, i need my BCM done for the HVAC upgrade to heated seats, DIC reprogram to correct milage, and speedo... hell anything to open up my BCM id be happy lol
  9. #9 Re: gxp speedo problem
    Oct 2011
    MI
    I'm located in Saginaw.
    You can't unlock a bcm. Sometimes you can program options or configuration but rarely . dic and speedo aren't a problem.Hvac would be a separate module that would be flashed/programmed..
    I can't remember ever seeing hvac on the list for a gp. Perhaps the wiring harness itself is physically different on cars with heated seats. I could look.
    Definitely an update for the pcm on our cars but if you tune with hpt or anything else the update would be pointless.
  10. #10 Re: gxp speedo problem
    London Ont, Canada
    ive seen it referenced many times here
    http://sm.gpona.com:9001/si/showPubS...316&name=Seats
  11. #11 Re: gxp speedo problem
    GTP Level Member
    Sep 2011
    Motown
    Alright I still have not came up the solution to fix my speedo. I tried using a tech2...couldnt figure it out...GRRR these lights are starting to bother me! haha
  12. #12 Re: gxp speedo problem
    I live here. DirtDog's Avatar
    Jun 2012
    Damn I know what ur problem is
  13. #13 Re: gxp speedo problem
    GTP Level Member
    Sep 2011
    Motown
    And what would that problem be? lol
  14. #14 Re: gxp speedo problem
    Jun 2012
    well for one if i remember correctly gxp speedo goes up higher in speeds...and for two its made for a v8 so you would probably need a tuner for it
  15. #15 Re: gxp speedo problem
    GTP Level Member
    Sep 2011
    Motown
    Ya i know that, I just dont understand how to get the tech 2 to reprogram the speedo..
  16. #16 Re: gxp speedo problem
    Jun 2012
    Hmmmmm
  17. #17 Re: gxp speedo problem
    Arizona
    I'm sure there's a way but have u considered just peeling off the Gxp overlay and putting it on the stocker
  18. #18 Re: gxp speedo problem
    GTP Level Member
    Sep 2011
    Motown
    I was honestly thinking of that today, but 80% of the reason I changed was because it went to 160. I have my original speedo apart at the moment trying to figure out which relay triggers or checks for abs/trac/brake. If there even is one lol
  19. #19 Re: gxp speedo problem
    Jun 2012
    if he peeled off the overlay and put it on the normal one his speedometer would be really off probably by about 10 miles per hour
  20. #20 Re: gxp speedo problem
    Comp g to GXP.
    Pretty sure the comp g one is the same as every other non GXP one
    04 Comp G.
  1. Speedo
    By crock in forum General Tech Discussion
    Last Post: 10-04-2011, 09:55 PM
  2. GXP speedo
    By Javi in forum Visual/Body Modifications
    Last Post: 03-14-2011, 12:15 AM
  3. Speedo vid *YAY*
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2009, 01:35 AM
  4. No speedo
    By mikebrowncustoms in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-16-2009, 11:17 PM
  5. 93 grand prix speedo problem
    By laxman87 in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-07-2008, 03:59 PM
