Thread: Aeroforce gauge question
Results 1 to 11 of 11
  1. #1 Aeroforce gauge question
    SE Level Member Hockey89's Avatar
    Mar 2012
    Layton, Utah
    I plugged my aeroforce gauge in and it won't turn on the red lights flash but the screen won't turn on. It worked originally when I first plugged it in and I can get it to come on if I unplug it then plug it back in. How do I fix this?
    2002 GTP, 160k miles, 8k HID, Custom CAI, ZZP Downpipe, ZZP Crossover, Special Edition Tips.
  2. #2 Re: Aeroforce gauge question
    Do you have the red jumper in the back removed and a constant 12v power source going to it from the 3 wire harness that you need?
  3. #3 Re: Aeroforce gauge question
    Mar 2012
    Layton, Utah
    I don't think I have the red jumper removed but I got the 12v installed
  4. #4 Re: Aeroforce gauge question
    Mar 2012
    Layton, Utah
    And I thought it was a switched? I got it hooked up to the radio right now.
  5. #5 Re: Aeroforce gauge question
    GT Level Member AaroGaming's Avatar
    Jun 2015
    Detroit, MI
    I still have this problem. And I've tried just about every fuse in my damn box to get this to work
    '02 GTP:​ Spectre intake, Borla cat-back, Aeroforce+boost gauges, custom pre-gen wheels, aftermarket sounds, KYB AGX w/ Vogtlands.
  6. #6 Re: Aeroforce gauge question
    Nov 2014
    BFE,Ohio
    i did mine to the sun roof with an add a circit
  7. #7 Re: Aeroforce gauge question
    Jun 2015
    Detroit, MI
    I have tried the radio, the sunroof, and just about every other turn-key accessory and I still have to re-plug it for anything to happen other than flashing lights! I can completely unplug the add-a-circuit and it has the same effect. It can power from the OBDII port, it just won't activate to display until I remove power and reapply it while the car is running.
    But I did notice that after I get it working, if I turn off the car it stays on for about 15-30 seconds, and if I restart the car in that time period it works perfectly.
  8. #8 Re: Aeroforce gauge question
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Try connecting it to the MALL PGM Fuse.
    That's where mine is, and havent had an issue. Also, make sure the red jumper in the back is removed.
  9. #9 Re: Aeroforce gauge question
    Jun 2015
    Detroit, MI
    Connected to Mall PGM
    No red jumper used.
    If I replugged it, it'll work for as long as it's running. If I turn it off and on again before the screen goes out it works. If the screen goes out before I start the car, I have to replug it to use it again.
  10. #10 Re: Aeroforce gauge question
    Jul 2010
    Coquitlam,BC,Canada
    What did Aeroforce say about this?
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  11. #11 Re: Aeroforce gauge question
    Jun 2015
    Detroit, MI
    I haven't contacted anyone from Aeroforce, I was hoping someone here would know so their reply could possibly help someone else in the future with the problem. I'm having
  1. Aeroforce gauge ?
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 04-16-2010, 06:04 PM
  2. Aeroforce scan gauge question
    By 98SilvermistGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2009, 06:47 PM
