This may be a stupid question but how do you attach subs to a box? I purchased them
separately
separately
Do i just screw right through the fabric and everything?
Yup, get some good solid wood screws, with a flat head.
I would put the sub in, set it how you want (angled right), take a drill with a small bore drill and make some pilot holes so you don't split the wood.
Remove sub and use vacuum to suck out the saw dust from drilling (we want a presentable box right?)
Put sub back, line up holes, and screw it in place.
Keep in mind, you want to be careful with the screw driver, if you slip off you can push the screw-driver throught the cone or excursion and ruin the woofer. Been there, broke that, felt stupid.
Just go slow, take your time, appreciate it once its all put together properly.
Yea it sounds odd, but the fabric is actually very thin but should be glued in place. Also why I suggested the drill for a pilot hole, makes a hole in the fabric easier. The fabric will help add as a gasket once the sub is torqued down so don't worry about it, there is a reason 99% of subs have 6-10 screw holes, they want you to use them all. Some woofers even come with a thin foam seal on the bottom to make it air tight.
just don't over tighten the screws and strip them out and you will be good to go.
I used 3/8 hex head screws with the most aggressive threads i could find, and a impact to get them all the way in..... That is the "exteme" way.
What stated above will work if you want a little bit more seal add a small bead of silicone if you don't have gaskets
There are better ways...
Like these:
Nuts / T-nuts in the Speaker Components Department at Parts Express | 313
You'll never have to worry about stripping the wood ever again.
You just have to get a big drill so you can make the recess so its flush. Otherwise you have a nice 1/16 gap between the box and woofer due to the metal.
But I'd agree, if done proper, this would be ideal, so you can un-mount the sub without having to worry.
if you're only running subs with a couple hundred watts, just use the screws into the particle board with the mentioned pilot hole. If you feel you need more security and want to run with the tee-nut option, I would suggest using a glue of some sort to hold the tee-nuts in place to reduce the chance of pushing them out while threading your screw in from the front of the enclosure. <--I think that made sence. I may or may not have said a few bad words because of this.
