Thread: Dual climate control ssues
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 63
  1. #1 Dual climate control ssues
    GT Level Member Dakoda's Avatar
    Feb 2013
    Illinois
    Ok i have the all digital dual climate control in my 99 gtp. No matter what setting its on (feet, defrost, etc) it always blows out of all the vents. I have never dealt with something like this before so any suggestions would be helpful.
  2. #2 Re: Dual climate control ssues
    the pump part in this pic is the part the controls the air flow, its vacuum operated. one of the vac lines atop of the sc powers it. check that the vac line is on and not cracked, it leads back to the fire wall. then to these 2 pumps, one on each side of the dash. that thin line off the top of it is the vac line.
    the part furthest to the right.
  3. #3 Re: Dual climate control ssues
    Feb 2013
    Illinois
    Ok i will check it as soon as i can and give an update
  4. #4 Re: Dual climate control ssues
    Feb 2013
    Illinois
    This may be a stupid question but are the pumps that the vacuum lines connect to in the engine bay somewhere or under the dash?
  5. #5 Re: Dual climate control ssues
    not sure where the line gets into the car, but that line on the sc gives it vac.
    take your glove box door off and look hard tot he left, thats where the pump is. theres a tube coming off it, thats the line form outside somehow. it splits into 2.
    http://www.grandprixforums.net/blend...ent-21941.html this shows you how to get to these pumps, they are talking about fix the blend door actuator, you want the pump, the round part.
    if you have some vac tubing laying around, take the line off the vac pump, put the new vac line on, and suck, and or blow into the vac line, see if the controls work, that lever should move up and down, or in and out of the pump if you will.
    you can also start the car and see if there any suction from the cars vac line.
  6. #6 Re: Dual climate control ssues
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    Or you can disconnect that same vac line in the engine bay, it goes over the passenger strut tower. I just put my finger on and off the end of it and it made things work again- something was clogged.
  7. #7 Re: Dual climate control ssues
    if you do take that vac hose off the tree on top of the sc, cut it off, ( used a sharp razor) then replace it with a 2 inch piece of vac line.
    one or the others going to break, either the line, or the tree, i bet they dont even charge you for 2 inches of vac line at the parts store.
  8. #8 Re: Dual climate control ssues
    Feb 2013
    Illinois
    you dont think i can get it off without breaking anything?
  9. #9 Re: Dual climate control ssues
    Quote Originally Posted by Dakoda View Post
    not a chance.
  10. #10 Re: Dual climate control ssues
    Sep 2012
    Clarkston, MI
    I popped mine off near the battery, kinda under the fuse box. There's a connector there also.
  11. #11 Re: Dual climate control ssues
    Feb 2013
    Illinois
    i might try that then
  12. #12 Re: Dual climate control ssues
    Feb 2013
    Illinois
    ok im gonna try the connector by the fuse box
  13. #13 Re: Dual climate control ssues
    its the same material as the T's, they break. like i said if they charge you for the 2 inches of tubing, id be very surprised. break the tree and your off to a dealer for a new one.
    see all the tubes have a lump in them, when you pull the line out of the factory tube, it splits. or you break the tree cause its also got a flared tube.
    see the small vac line and that bulge, they all have that, i just didnt push the new line past it.
    this pic you can kinda tell thats a new piece of vac line on the line that run to the fender the small rear line on on the tree.
  14. #14 Re: Dual climate control ssues
    Feb 2013
    Illinois
    In that case ill just wait till i get home... im pretty sure i have extra vac lines layin around ill just cut it off i dont need to break anything
  15. #15 Re: Dual climate control ssues
    yup, just dont push down hard on the tree when cutting, the tube is off the ground so to say, so support it and cut nice and easy, once its cut through it slides right off. pain less. spit on the new line, slide it on. good old dude lube strikes again.......
    sharp blade is key.
  16. #16 Re: Dual climate control ssues
    Feb 2013
    Illinois
    ok i got up under the dash today and looked at both of the actuators... they both have everything hooked up and looks to be in good condition... i started the car and turned the heat on and changed modes and the actuators did nothing.. what could be the cause of this?
  17. #17 Re: Dual climate control ssues
    pull the vac line off the vac pumps there, and start the car see if the tube sucks.
    the climate control must tell something else to suck or not on that line, so change the air flow ( floor, to vent to defrost) while feeling for the tub to suck.
  18. #18 Re: Dual climate control ssues
    Feb 2013
    Illinois
    ok ill try that tomorrow
  19. #19 Re: Dual climate control ssues
    Feb 2013
    Illinois
    also what controls what it says for the outside temp cuz mine is always saying around 10 degrees or lower and i know its not accurate
  20. #20 Re: Dual climate control ssues
    that may be a factor. open the hood, look down pretty much dead center by the rad and bumper theres a sensor mounted to some metal there, its a dealer only part as far as i know. i know it will mix up the a/c and it wont work right if it bad. maybe the same is for the heat?
    if its broke fix it, go from there i guess.
  1. dual climate control help
    By skylar44 in forum General Tech Discussion
    Last Post: 08-18-2012, 06:31 PM
  2. dual climate control
    By tedbuido in forum General Tech Discussion
    Last Post: 04-04-2011, 10:37 PM
  3. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
  4. will 05 dual climate control fit in an 04 gt2?
    By gp04duff in forum General Tech Discussion
    Last Post: 12-01-2008, 07:08 AM
  5. Dual climate control
    By 04gpking85 in forum General Tech Discussion
    Last Post: 10-12-2008, 11:41 PM
