Thread: Dual climate control ssues
Results 41 to 60 of 63
  1. #41 Re: Dual climate control ssues
    GT Level Member Dakoda's Avatar
    Feb 2013
    Illinois
    Found a working climate control at a yard and plugged it in and it did the same thing... So it's gotta be a vaccum leak right?
  2. #42 Re: Dual climate control ssues
    you ever pull the vac lines off the vac actuators in the dash to see if they suck or not? id test that. and you can try to move the arm off the vac actuator (moving this arm should change the flow of air) as well as see if they move on their own when you change the settings, also see if the vac line sucks as you change the settings.
    if all that moves on its own, then the end of the rod may have broken off. you'll need to test both sides, you cant just look at the pass side, i know its easy but theres 2 of them, if ones broke, like in gregbadass's car, iirc his was stuck on a mix of defrost and vent, and the plastic arm was broke off near the top of the hvac box. they did rig a repair.
  3. #43 Re: Dual climate control ssues
    Feb 2013
    Illinois
    Ill do that today and update
  4. #44 Re: Dual climate control ssues
    Feb 2013
    Illinois
    I can't feel any vaccum on the yellow line coming off the top of the actuator
  5. #45 Re: Dual climate control ssues
    even when changing the setting from defrost, vent and floor? it should suck for some and not for the other.
    if nothing you need to trace the vac line off the top of the sc, all the way around the engine bay and look for a leak or break.
  6. #46 Re: Dual climate control ssues
    Feb 2013
    Illinois
    I traced the line until it goes into the plastic surround ****... I saw setting that said there's supposed to be a t on that line going over to the driver side of the engine bay is that true?
  7. #47 Re: Dual climate control ssues
    take a pic of what your talking about.
  8. #48 Re: Dual climate control ssues
    Feb 2013
    Illinois
    Txt me and ill send you the pics it's a ***** postin em on here 3096606995
  9. #49 Re: Dual climate control ssues
    i knew id find one in one of Bills posts. so glad he takes pics of stuff. vac ball under the head light in the fender/bumper cover.
    http://www.grandprixforums.net/vacuu...ing-72507.html
  10. #50 Re: Dual climate control ssues
    Feb 2013
    Illinois
    Ill look into it tomarow thanks again
  11. #51 Re: Dual climate control ssues
    Feb 2013
    Illinois
    Ya That ball on the drivers side in the picture is non existant in my car... i guess that explains why its not working like it should. Where does the vaccum line from that ball go to? i guess ill be taking a trip to the junk yard in the near future
  12. #52 Re: Dual climate control ssues
    from what i got from the other thread posted, that guy also had no ball there. and said he hooked the line up to another line that went into the cab, then it all worked.
    were you able to follow that vac line to the d/s fender? if so did it just end there open ended?
  13. #53 Re: Dual climate control ssues
    Feb 2013
    Illinois
    I couldnt even find a line that went to the drivers side fender...
  14. #54 Re: Dual climate control ssues
    its the one that comes off the sc, then leads to the pass side fire wall, then down to the battery, then across the rad, to the ball. where it goes from the ball i have no idea.
  15. #55 Re: Dual climate control ssues
    Feb 2013
    Illinois
    Mine just goes to the firewall then down by the battery then into the plastic tubing surrounding the wiring that goes in through the firewall... nothing goes across from that line
  16. #56 Re: Dual climate control ssues
    Feb 2013
    Illinois
    ok i have done all of my vac line tracing and everything is ok... ive tried a different control unit and it did the same thing, and now i notice that when my heat/air is off i hear what sounds like the actuator on the passenger side moving in and out.. im so confused at this point should i just buy new actuators?
  17. #57 Re: Dual climate control ssues
    GT Level Member 1996pontiac's Avatar
    Livonia, Michigan, United States
    I have a similar problem with mine. AC comes out cold on one side and not the other. I'm assuming that it is the blend door. Could i put in a regular duel climate control with out the temp reading and will it work?
    1999 Red Pontiac Grand Prix GTP/120xxx miles
    Mods- Intake
  18. #58 Re: Dual climate control ssues
    Quote Originally Posted by Dakoda View Post
    did you ever take the panels off to see if the vac pumps move, or if you move the lever if the air flow changes? the plastic are could be broken on top of the hvac box, where the linkage leads to.
    clicking could be a blend door actuator, but that only affects hot or cold air. once all the panels are off, if you hear the clicking, you can reach in and touch the actuator, you should feel it clicking if its making the sounds.
  19. #59 Re: Dual climate control ssues
    Feb 2013
    Illinois
    ok i finally got around to taking my dash apart... the pass side actuator is the culprit for the squeaking noise it sounds like its trying to go in and out but the arm doesnt move an inch...
  20. #60 Re: Dual climate control ssues
    maybe its dead? have you tried to move the arm yourself yet? or pull the line off it to check for vacuum of some sort? at least the pass side is easier to work on.
    was that you texting me a night ago or so? i was out and had no clue who was texting me, or what the pic was of. lol sorry i was unable to get back to you if it was you. sounds like it now looking back.....
  1. dual climate control help
    By skylar44 in forum General Tech Discussion
    Last Post: 08-18-2012, 06:31 PM
  2. dual climate control
    By tedbuido in forum General Tech Discussion
    Last Post: 04-04-2011, 10:37 PM
  3. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
  4. will 05 dual climate control fit in an 04 gt2?
    By gp04duff in forum General Tech Discussion
    Last Post: 12-01-2008, 07:08 AM
  5. Dual climate control
    By 04gpking85 in forum General Tech Discussion
    Last Post: 10-12-2008, 11:41 PM
