Thread: Grounding Two Amplifiers
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #1 Re: Grounding Two Amplifiers
    Yoga city
    as this can be good, sometimes you can run into issues with sharing a ground, ie loops n such.
  2. #2 Re: Grounding Two Amplifiers
    Dec 2010
    ATL,Georgia
    Do as DanPrix said... I don't know why people are making this more complicated with talk of running a ground all the way to the battery and such.... get a distribution block... run each amp to that, then ground it to the chassis by getting to bare metal... I had three amps running this way 2 Rockford 1000 monos and 1 Rockford 500 multichannel
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  3. #3 Re: Grounding Two Amplifiers
    Yoga city
    i think the ppl chiming in with running other ground locals, have been throught the bs before, or remedy for voltage drop. Granted the guy above me is saying all these amps where fine, That is not correct, bare metal isnt always just the best. maybe if youve done big three and kknow you have good grounds.
  4. #4 Re: Grounding Two Amplifiers
    Northeast Ohio
    my amps were fine and ran great for almost the 2 yrs i had the set-up before just selling the car....big 3 and extra battery to keep the mrp-m1000 happy down at 1 ohm grounds were solid and fine, i mean NEVER had any issue even at 147.3db
  5. #5 Re: Grounding Two Amplifiers
    Dec 2010
    ATL,Georgia
    Ya I have done big 3 and running 0 gauge right now... I'm just saying all the systems I have setup have run this way and with no power or voltage problems.. ideally yes you would want to ground to the battery... but the other way will suffice just as well.. even in big power setups
    And yes I didn't mean just screw right into the trunk metal.. like you said yes you need to find a good ground on bare metal
  6. #6 Re: Grounding Two Amplifiers
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Ground loops can occur when "sharing" a ground.
    But hey, I got good news you.
    They actually invented something called a ground loop isolator.
    It eliminates the ground loop. Outstanding isnt it?
    And on the plus side, they are cheap.
  7. #7 Re: Grounding Two Amplifiers
    Yoga city
    Use a ground loop isolator, I just won't let myself use a bandaid. Fix the issue not add more stuff to mask it.
  8. #8 Re: Grounding Two Amplifiers
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    for now i changed the one ground for the subs amp to the strut tower and plan to move the smaller amp for the speakers to the other strut tower when i get the chance as well
  1. Grounding Kit
    By Dee23 in forum Audio, Security & Visual Electronics
    Last Post: 10-11-2012, 12:32 AM
  2. Stereo grounding
    By mikejon in forum Audio, Security & Visual Electronics
    Last Post: 03-20-2011, 03:53 PM
  3. Mounting Amplifiers to Trunk Lid
    By chamilton89 in forum Audio, Security & Visual Electronics
    Last Post: 03-14-2011, 08:16 PM
  4. Grounding both amps?
    By Magnaflow GP in forum Audio, Security & Visual Electronics
    Last Post: 03-08-2010, 03:52 PM
  5. Grounding points // Voltage Drops...
    By Toofastgs in forum Audio, Security & Visual Electronics
    Last Post: 09-09-2008, 09:21 PM
