Thread: Wiring Harness Question!
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 Wiring Harness Question!
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    i appreciate all the help ive been getting from this forum. thank you guys so much!! one last question i have is about a wire harness for the head unit.
    MY SPECS:
    05 grand prix base model
    on star (never used)
    non-monsoon system
    WHAT I WANT:
    just to be able to hook up an after market head unit with ease
    dont care if i lose on star
    dont care if i lose door chimes
    i believe this is the harness i need. can anyone verify this?
    Metra 70-2003 Wiring Harness for Select 1998-2009 GMC Vehicles
  2. #2 Re: Wiring Harness Question!
    Nov 2011
    Decatur
    bump
  3. #3 Re: Wiring Harness Question!
    Houston
    Yeah, that should work. I think there are some options in you DIC that you'll lose as well, like date/time. You will also have to run your own switched 12v line, you wont be able to use the one on the main harness.
  4. #4 Re: Wiring Harness Question!
    Nov 2011
    Decatur
    so could I put an add a fuse in the passenger fuse box and use the liitle cord off it for my 12v source?
  5. #5 Re: Wiring Harness Question!
    Houston
    Yes, if you can find a switched 12v at your fuse box. And that harness looks like it comes with one.
  6. #6 Re: Wiring Harness Question!
    Nov 2011
    Decatur
    awesome! do you know if its safeto use more than one add a fuse?
  7. #7 Re: Wiring Harness Question!
    Houston
    You sure can.
  8. #8 Re: Wiring Harness Question!
    Feb 2009
    Virginia
    You'll lose door chimes, date on DIC, and anything else that runs through R.A.P. Unless you tap into another R.A.P. system for power your radio won't turn on either; you'll have to add a switch and use 12V-always_on for the power source
    11 is louder than 10!
  9. #9 Re: Wiring Harness Question!
    Nov 2011
    Decatur
    there are some fuses that are only on when the car is aren't there?
  10. #10 Re: Wiring Harness Question!
    New Brunswick
    Sunroof fuse is the best one to tap into, and you have one regardless of having a sunroof or not.
  11. #11 Re: Wiring Harness Question!
    Nov 2011
    Decatur
    do you have a diagram of which one it is? (i have no sunroof)
  12. #12 Re: Wiring Harness Question!
    Nov 2011
    Decatur
    ive read some people have issues with no sound out of their speakers. will this be an issue?
  13. #13 Re: Wiring Harness Question!
    GT Level Member GrandprixGT01's Avatar
    Nov 2011
    Keswick, Ontario
    The only reason to why you wouldnt get any sound is because something wouldnt be hooked up right, other then that from what I know and as long as you wire the harness correctly no problems.
  14. #14 Re: Wiring Harness Question!
    Nov 2011
    Decatur
    so if i tap into a switched fuse such as the sunroof, this wire harness will be of no issues?
  15. #15 Re: Wiring Harness Question!
    Houston
    People are running into "no sound" because they are not hooking up the stock amp turn on. You said you dont have monsoon, so you wont have this problem. If you dont have power to your radio, you are not on a 12v circuit.
  16. #16 Re: Wiring Harness Question!
    Nov 2011
    Decatur
    alright thanks for the help
  17. #17 Re: Wiring Harness Question!
    Nov 2011
    Decatur
    one other question i have is that today i went to take out the head unit to make sure i knew what i was doing and everything would go smoothly before i just dived into it head first. so my question is that on the back of the head unit it has two plug ins but the adapter only has one. why is this? or is this a problem?
    and this is the correct fuse right? the far left yellow one
  18. #18 Re: Wiring Harness Question!
    Houston
    Im thinking the second harness behind your radio is probably for your steering wheel controls. As for the fuse, Im not sure. You'll have to test for the correct one.
  19. #19 Re: Wiring Harness Question!
    Nov 2011
    Decatur
    I do not have steering wheel controls.. could it be for onstar? if you're unsure what I am talking about I could take a picture of it tomorrow
  20. #20 Re: Wiring Harness Question!
    New Brunswick
    That fuse is the correct one.
    The second little black connector from the back of the radio is for onstar if you have it, xm radio if you have it, and monsoon system i beleave has a wire or two in it as well if you have it.
    If you have a non bose system you only need the bigger grey connector to be used. your factory radio should work no different if you try using it with this connector unplugged.
  1. 04+ head unit install
    By brian76708 in forum Audio, Security & Visual Electronics
    Last Post: 10-16-2011, 11:00 AM
  2. Wanting to install a new head unit
    By kurukato in forum Audio, Security & Visual Electronics
    Last Post: 09-24-2011, 10:03 AM
  3. Is it possible to install a new head unit FLUSH?
    By nickbuol in forum Audio, Security & Visual Electronics
    Last Post: 01-17-2011, 12:36 PM
  4. New Head Unit
    By redrider57 in forum Audio, Security & Visual Electronics
    Last Post: 08-23-2010, 07:30 PM
  5. General questions - Head Unit and such
    By Jcal1120 in forum Audio, Security & Visual Electronics
    Last Post: 10-28-2009, 11:30 PM
