Thread: Wiring Harness Question!
Results 21 to 40 of 41
  1. #1 Re: Wiring Harness Question!
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    awesome thank you!
  2. #2 Re: Wiring Harness Question!
    SE Level Member spac31's Avatar
    Aug 2011
    Los Angeles, CA
    You guys are awesome. Took me a while to find a thread like this. Thanks so much. This is good for both single and double din stereos correct? As i have a double din just sitting around.
  3. #3 Re: Wiring Harness Question!
    Nov 2011
    Decatur
    Quote Originally Posted by spac31 View Post
    i installed this headunit so yes
  4. #4 Re: Wiring Harness Question!
    GT Level Member des19's Avatar
    May 2011
    Ontario
    I would save yourself the trouble and just pick up the gmos-04. Retains everything, chimes, onstar, etc. Can be picked up on ebay for 45$. Also has a 12v switched source wire. Very easy install
  5. #5 Re: Wiring Harness Question!
    Aug 2011
    Los Angeles, CA
    @des19
    so would it be different if used a gmos-1 instead of a gmos-4 since my car is not amplified?
    @2dee11
    Wow, that thing is nice. New Pioneer model? Does your unit still stay on until you open the door when you turn the car off? where did u get the 12 volt for switched power? Pic?
  6. #6 Re: Wiring Harness Question!
    May 2011
    Ontario
    @des19
    @2dee11
    The gmos 1 works the same way as the gmos 4 except the 1 is for non amplified gm vehicles. The gmos-01 will also just be a plug and play install very easy and retains everything except wheel controls. For this u need a separate adapter like a PAC module. gmos-01 is the way to go very easy install will definately save u a lot of headaches.
  7. #7 Re: Wiring Harness Question!
    Nov 2011
    Decatur
    i have a 2005 base model, so this could be a little different than yours. i used:
    this harness adapter Amazon.com: Metra 70-2003 Radio Wiring Harness For GM 98-Up Harness: Car Electronics
    with this antenna adapter http://www.amazon.com/gp/product/B00...ls_o01_s00_i01
    with this dash kit http://www.amazon.com/gp/product/B00...ls_o02_s00_i01
    aswell as a similar add a circuit from autozone (or loca autoparts store) like this one Cooper Bussmann/ATM fuse tap converts one into two fusible circuits - 10 Amps maximum on added circuit (BP-HHH-RP) | Fuse and Accessories | AutoZone.com
    i did end up losing my door chimes and onstar, but this was no problem for me because i hated the chimes and never used onstar...
    i got my switched power source using the add a circuit in the "sun roof" fuse on the passenger side fuse box (i dont not have a sun roof but all grand prix's have this so ive been told)
    closer view
    i just ran the wire hidden up under the dash to the head unit
    finished pics
    yes the radio does stay on until i open the door after i turn the car off. The model is the Pioneer AVH-P1400DVD
    Apr 2012
    rhode island
    I hate that they put the USB port in the front of the radio I think it looks cheap to have wires coming out IMO. I personally wouldn't spend that much on a unit that does that. But I'm glad u got everything working I will be installing a double din soon also
  9. #9 Re: Wiring Harness Question!
    Nov 2011
    Decatur
    Quote Originally Posted by illy View Post
    i agree i realized this about a week after i got it, but oh well!
  10. #10 Re: Wiring Harness Question!
    Aug 2011
    Los Angeles, CA
    @2dee11: so i found the add a circuit. do i put two 10a fuses or do i put the 10a fuse on the top and the 20a fuse on the bottom?
    @des19: sop i've been looking for a harness but they all seem to be 70 and up. any specific retailer i should look for?
  11. #11 Re: Wiring Harness Question!
    Nov 2011
    Decatur
    @spac31 umm... i think it just depends. my add a circuit was capable up to 20A i think and i put it in the sun roof which is 20A so i put two 10A fuses in it
  12. #12 Re: Wiring Harness Question!
    May 2011
    Ontario
    ebay and amazon are your friend.
    Axxess GMOS-01 02-Up Onstar Harness Adapter with Chime | eBay
  13. #13 Re: Wiring Harness Question!
    Aug 2011
    Los Angeles, CA
    Okay so if i pull my stock stereo out to plug in the new wire harness and make sure it works, will it lock up on me?
  14. #14 Re: Wiring Harness Question!
    Nov 2011
    Decatur
    I don't think so.. I took mine out then realized I had forgotten a CD in it and plugged it back in to get it out.. seemed to work fine when I plugged it back in
  15. #15 Re: Wiring Harness Question!
    Aug 2011
    Los Angeles, CA
    okay guys i got it going! Now one last question, 2dee11 did you bypass ur parking brake?
  16. #16 Re: Wiring Harness Question!
    Nov 2011
    Decatur
    sorry for the late response, i've been busy with finishing up school this past week but yes i did bypass it
  17. #17 Re: Wiring Harness Question!
    Banned
    Sioux Falls, SD
    This harness will keep all ur chines, alerts, onstar, and the rap. its expensive but well worth it!
    Axxess GMOS100 Wiring Harness for Replacing the OEM Radio in GM
  18. #18 Re: Wiring Harness Question!
    Aug 2011
    Los Angeles, CA
    THanx guys... Decided to go with the metra harness, (didn't really see the need for the on-star or warning chimes) and I managed to fix the whole parking brake thing.
  19. #19 Re: Wiring Harness Question!
    Oct 2012
    Brampton,ON
    I was wondering if with the harness are you still able see you km you have driven, are you able to see Trip A and Trip B feature, and do you still get the warnings for oil changes and stuff? I wanna change the radio but i dont wanna lose the km feature, im not really worried about the calendar.
    Quote Originally Posted by Acedriver View Post
    Yup that all remains
    Only thing your losing is the calendar feature but hell that's what a cell phone is for.
    04 Comp G.
  1. 04+ head unit install
    By brian76708 in forum Audio, Security & Visual Electronics
    Last Post: 10-16-2011, 11:00 AM
  2. Wanting to install a new head unit
    By kurukato in forum Audio, Security & Visual Electronics
    Last Post: 09-24-2011, 10:03 AM
  3. Is it possible to install a new head unit FLUSH?
    By nickbuol in forum Audio, Security & Visual Electronics
    Last Post: 01-17-2011, 12:36 PM
  4. New Head Unit
    By redrider57 in forum Audio, Security & Visual Electronics
    Last Post: 08-23-2010, 07:30 PM
  5. General questions - Head Unit and such
    By Jcal1120 in forum Audio, Security & Visual Electronics
    Last Post: 10-28-2009, 11:30 PM
