That fuse is the correct one.
The second little black connector from the back of the radio is for onstar if you have it, xm radio if you have it, and monsoon system i beleave has a wire or two in it as well if you have it.
If you have a non bose system you only need the bigger grey connector to be used. your factory radio should work no different if you try using it with this connector unplugged.
