Thread: Subs in different boxes
Results 1 to 20 of 29
  1. #1 Subs in different boxes
    Jersey
    I have considered getting two new 12" subs as my ears has had enough of hearing my Sony xplods lol. There's nothing wrong with them to me. I just wanna hear more of the low notes so its time to move on. My situation is that i love the box that came with the subs. I was wondering if i can buy the new subs and put them in the Sony box? Thanks
    I live here. DirtDog's Avatar
    Jun 2012
    Yes they should work. Is it a full size sub box? Also I would try and use the same screw holes
    Sent from my DROID RAZR using Tapatalk 2
  3. #3 Re: Subs in different boxes
    Jersey
    I believe so. Its the box with the slant in the back of it and the big ported hole on the side
  4. #4 Re: Subs in different boxes
    Jun 2012
    yea you should be fine to switch the subs out. i used to have a explode in my old car and i swapped it out with a kicker no problem
  5. #5 Re: Subs in different boxes
    GTX Level Member blakgtp's Avatar
    Sep 2011
    Vancouver
    the box is more important than the subs. prefab enclosures have a really bad rep
    97 gtp- 3.5 pulley, sd headers, autolite 104's, dhp pcm, hai, 180 t-stat SOLD
    94 skyline- drift slut SOLD
    97 rx7 fd3s twin turbo SOLD
    99 R34 skyline
    Only one way to find out is to try a different set of subs. Boxes are usually designed specifically for the subs they come with. Just throwing any subs in it can hender the performance.
    04 Comp G.
    Jun 2012
    That as well. But when I put my kicker in it I noticed a noticeable but good difference
    All you can do is try sometimes it works just fine other times it doesn't. Worse case scenario you just have a box made for the new subs 8) I usually just have my box made specially for what sub I want to use.
    04 Comp G.
  9. #9 Re: Subs in different boxes
    Jersey
    Ok i'll give it a try first and see how it sounds. Btw its gonna be 2 Earthquake Sound DBXI 12s
  10. #10 Re: Subs in different boxes
    Northeast Ohio
    yeah the install which would include the box is 80% of the sub system the driver itself is important but i can make a 100 dollar sub in the right box sound better then a 800 dollar sub in a crappy prefab
  11. #11 Re: Subs in different boxes
    One of my older set ups back when I was into the audio thing.
    04 Comp G.
  12. #12 Re: Subs in different boxes
    Sep 2011
    Vancouver
    whenever i see a sub box facing back all i can think of is trunk rattle. in my car i couldn't hear it in the car but outside it was horrible lol. nice setup regardless
    99 R34 skyline
  13. #13 Re: Subs in different boxes
    Antioch, IL
    look at the sub specs, in reality no box is built for other subs. subs thats a lol. buy 1 good one, trunk isnt big enough for 2 properly installed ported beasts.
    2009 Challenger SRT8
    Expert at being gay.
  14. #14 Re: Subs in different boxes
    Sep 2011
    Vancouver
    Quote Originally Posted by ITHURTZ View Post
    could definitely fit 2 12's in a ported box. I have my fi bl in a 4.4 cube (after port and sub) box was a tight fit but got it to slide in
    99 R34 skyline
  15. #15 Re: Subs in different boxes
    Quote Originally Posted by blakgtp View Post
    Actually wasn't bad at all. There was a little rattle.
    04 Comp G.
  16. #16 Re: Subs in different boxes
    Antioch, IL
    need bigger sub if 2 fit, or tune to 28hz
    GT Level Member maverickdog8's Avatar
    Bettendorf, Iowa
    Boxes are built(most of the time) for 1 specific sub. Each sub(once again most of the time) has a different air space requirement. Boxes are easy to build.
  18. #18 Re: Subs in different boxes
    GTX Level Member mofford12's Avatar
    Nov 2012
    Cincinnati
    memphis mojo?
    M3!
    04 Comp G.
  20. #20 Re: Subs in different boxes
    Nov 2012
    Cincinnati
    nice! never used mojo.. how was it
  1. Fiberglass VS. Wooden Sub Boxes
    By SliceTheRice in forum Audio, Security & Visual Electronics
    Last Post: 08-03-2010, 04:04 PM
  2. DD subs in a GP
    By offroadfury6 in forum Audio, Security & Visual Electronics
    Last Post: 07-09-2009, 03:10 PM
  3. installs and boxes built (unkind to 56k, pic heavy)
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 02-17-2008, 08:13 PM
