Thread: Help with aftermarket headunit instead of monsoon
Results 21 to 40 of 44
  1. #21 Re: Help with aftermarket headunit instead of monsoon
    GTP Level Member simbah's Avatar
    Lala land
    You shouldn't have to bother with the smaller second plug.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  2. #22 Re: Help with aftermarket headunit instead of monsoon
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    its the tan wire on the little connector splice the blue white wire to it and bam working radio
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  3. #23 Re: Help with aftermarket headunit instead of monsoon
    Lala land
    the smaller plug has the speed sensor wiring for the variable volume control
  4. #24 Re: Help with aftermarket headunit instead of monsoon
    Sep 2012
    bridgeport,NY
    not with the factory amp its the same with bose
  5. #25 Re: Help with aftermarket headunit instead of monsoon
    gardner,mass
    Quote Originally Posted by Erik Adam Rodriguez View Post
    the blue wire coming form that aftermarket wiring harness? so basicly create a loop to the smaller connecter?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  6. #26 Re: Help with aftermarket headunit instead of monsoon
    Sep 2012
    bridgeport,NY
    im sorry didnt look at the hu wires splice that tan wire to the red ingition wire pardon my spelling
  7. #27 Re: Help with aftermarket headunit instead of monsoon
    gardner,mass
    ya i just put that blue and white amp on wire and put it to the tan on the small connector and nothing
    So you want me to take the tan on the small and put it to the red acc wire?
  8. #28 Re: Help with aftermarket headunit instead of monsoon
    Sep 2012
    bridgeport,NY
    yes
  9. #29 Re: Help with aftermarket headunit instead of monsoon
    gardner,mass
    yes
    Nothing, nothing and stil........ nothing
    I think the unit is bad there is power to it adn i cant change anything like its frozen in place
  10. #30 Re: Help with aftermarket headunit instead of monsoon
    Sep 2012
    bridgeport,NY
    try getting another hu and see i had to go throught 3 hu until i bought one brand new
  11. #31 Re: Help with aftermarket headunit instead of monsoon
    gardner,mass
    yea thats very disapointing cus i trading some rims for 200$ hu and an equaliser
  12. #32 Re: Help with aftermarket headunit instead of monsoon
    Sep 2012
    bridgeport,NY
    i just sold a deck for 40 bucks it was brandnew in box i just didnt need it
  13. #33 Re: Help with aftermarket headunit instead of monsoon
    gardner,mass
    what do you guys make of this
    2004 Pontiac Grand Prix Car Stereo Wiring Diagram
    Car Radio Battery Constant 12v+ Wire: Orange
    Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox or ignition switch harness for switched power.
    Car Radio Ground Wire: Black/White
    Car Radio Illumination Wire: Violet
    Car Stereo Dimmer Wire: Violet
    Car Stereo Antenna Trigger Wire: N/A
    Car Stereo Amp Trigger Wire: N/A
    Car Stereo Amplifier Location: Located under the center of the rear deck.
    Car Audio Front Speakers Size: N/A
    Car Audio Front Speakers Location: N/A
    Left Front Speaker Positive Wire (+): Tan
    Left Front Speaker Negative Wire (-): Gray
    Right Front Speaker Positive Wire (+): Light Green
    Right Front Speaker Negative Wire (-): Dark Green
    Car Audio Rear Speakers Size: N/A
    Car Audio Rear Speakers Location: N/A
    Left Rear Speaker Positive Wire (+): Brown
    Left Rear Speaker Negative Wire (-): Yellow
    Right Rear Speaker Positive Wire (+): Dark Blue
    Right Rear Speaker Negative Wire (-): Light Blue
  14. #34 Re: Help with aftermarket headunit instead of monsoon
    Sep 2012
    bridgeport,NY
    saw that same one till i found one with the monsoon package this is for base model radio
  15. #35 Re: Help with aftermarket headunit instead of monsoon
    gardner,mass
    where did you find the monsoon one
  16. #36 Re: Help with aftermarket headunit instead of monsoon
    Sep 2012
    bridgeport,NY
  17. #37 Re: Help with aftermarket headunit instead of monsoon
    Sep 2012
    bridgeport,NY
    lt green wire on the plug from the car needs switched power just found that on google
  18. #38 Re: Help with aftermarket headunit instead of monsoon
    gardner,mass
  19. #39 Re: Help with aftermarket headunit instead of monsoon
    Sep 2012
    bridgeport,NY
    so pin eight tn is what you need to power i would try that
  20. #40 Re: Help with aftermarket headunit instead of monsoon
    gardner,mass
    im confuse on what the two connecters are
  1. 04+ Gp with monsoon and onstar double din headunit swap
    By painthorsemoe in forum Audio, Security & Visual Electronics
    Last Post: 01-31-2013, 04:56 PM
  2. aftermarket headunit in 06 gxp
    By nicks98gtp in forum Audio, Security & Visual Electronics
    Last Post: 11-28-2011, 01:45 AM
  3. Installing headunit in 04 GT2 with Monsoon
    By nickleahy23 in forum Audio, Security & Visual Electronics
    Last Post: 08-30-2011, 05:07 PM
  4. Best Aftermarket Headunit?
    By ajc549FF in forum Audio, Security & Visual Electronics
    Last Post: 03-04-2011, 01:01 AM
  5. 2004 monsoon + aftermarket headunit
    By blabo219 in forum Audio, Security & Visual Electronics
    Last Post: 02-03-2010, 03:10 PM
