Thread: Help with aftermarket headunit instead of monsoon
Results 1 to 20 of 44
Timing Help with aftermarket... 01-31-2013, 09:16 PM
Erik Adam Rodriguez Re: Help with aftermarket... 01-31-2013, 09:18 PM
Timing Re: Help with aftermarket... 01-31-2013, 09:22 PM
Erik Adam Rodriguez Re: Help with aftermarket... 01-31-2013, 09:25 PM
Timing Re: Help with aftermarket... 01-31-2013, 09:27 PM
Erik Adam Rodriguez Re: Help with aftermarket... 01-31-2013, 09:34 PM
Timing Re: Help with aftermarket... 01-31-2013, 09:35 PM
Erik Adam Rodriguez Re: Help with aftermarket... 01-31-2013, 09:37 PM
Timing Re: Help with aftermarket... 01-31-2013, 09:46 PM
Timing Re: Help with aftermarket... 01-31-2013, 09:40 PM
Erik Adam Rodriguez Re: Help with aftermarket... 01-31-2013, 09:41 PM
Timing Re: Help with aftermarket... 01-31-2013, 09:48 PM
Erik Adam Rodriguez Re: Help with aftermarket... 01-31-2013, 09:48 PM
simbah Re: Help with aftermarket... 01-31-2013, 09:53 PM
Timing Re: Help with aftermarket... 01-31-2013, 09:56 PM
Timing Re: Help with aftermarket... 01-31-2013, 09:59 PM
simbah Re: Help with aftermarket... 01-31-2013, 09:58 PM
Erik Adam Rodriguez Re: Help with aftermarket... 01-31-2013, 09:59 PM
simbah Re: Help with aftermarket... 01-31-2013, 10:01 PM
Erik Adam Rodriguez Re: Help with aftermarket... 01-31-2013, 10:02 PM
Timing Re: Help with aftermarket... 01-31-2013, 10:04 PM
simbah Re: Help with aftermarket... 01-31-2013, 10:03 PM
Erik Adam Rodriguez Re: Help with aftermarket... 01-31-2013, 10:04 PM
Erik Adam Rodriguez Re: Help with aftermarket... 01-31-2013, 10:08 PM
Timing Re: Help with aftermarket... 01-31-2013, 10:10 PM
Erik Adam Rodriguez Re: Help with aftermarket... 01-31-2013, 10:12 PM
Timing Re: Help with aftermarket... 01-31-2013, 10:17 PM
Erik Adam Rodriguez Re: Help with aftermarket... 01-31-2013, 10:19 PM
Timing Re: Help with aftermarket... 01-31-2013, 10:21 PM
Erik Adam Rodriguez Re: Help with aftermarket... 01-31-2013, 10:22 PM
Timing Re: Help with aftermarket... 01-31-2013, 10:34 PM
Erik Adam Rodriguez Re: Help with aftermarket... 01-31-2013, 10:43 PM
Erik Adam Rodriguez Re: Help with aftermarket... 01-31-2013, 10:35 PM
Timing Re: Help with aftermarket... 01-31-2013, 10:41 PM
Erik Adam Rodriguez Re: Help with aftermarket... 01-31-2013, 10:45 PM
Timing Re: Help with aftermarket... 01-31-2013, 10:52 PM
Erik Adam Rodriguez Re: Help with aftermarket... 01-31-2013, 10:57 PM
Timing Re: Help with aftermarket... 01-31-2013, 10:59 PM
Erik Adam Rodriguez Re: Help with aftermarket... 01-31-2013, 11:00 PM
Timing Re: Help with aftermarket... 01-31-2013, 11:09 PM
Erik Adam Rodriguez Re: Help with aftermarket... 02-01-2013, 11:08 AM
  1. #1 Re: Help with aftermarket headunit instead of monsoon
    gardner,mass
    what do you guys make of this
    2004 Pontiac Grand Prix Car Stereo Wiring Diagram
    Car Radio Battery Constant 12v+ Wire: Orange
    Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox or ignition switch harness for switched power.
    Car Radio Ground Wire: Black/White
    Car Radio Illumination Wire: Violet
    Car Stereo Dimmer Wire: Violet
    Car Stereo Antenna Trigger Wire: N/A
    Car Stereo Amp Trigger Wire: N/A
    Car Stereo Amplifier Location: Located under the center of the rear deck.
    Car Audio Front Speakers Size: N/A
    Car Audio Front Speakers Location: N/A
    Left Front Speaker Positive Wire (+): Tan
    Left Front Speaker Negative Wire (-): Gray
    Right Front Speaker Positive Wire (+): Light Green
    Right Front Speaker Negative Wire (-): Dark Green
    Car Audio Rear Speakers Size: N/A
    Car Audio Rear Speakers Location: N/A
    Left Rear Speaker Positive Wire (+): Brown
    Left Rear Speaker Negative Wire (-): Yellow
    Right Rear Speaker Positive Wire (+): Dark Blue
    Right Rear Speaker Negative Wire (-): Light Blue
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  2. #2 Re: Help with aftermarket headunit instead of monsoon
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  1. 04+ Gp with monsoon and onstar double din headunit swap
    By painthorsemoe in forum Audio, Security & Visual Electronics
    Last Post: 01-31-2013, 04:56 PM
  2. aftermarket headunit in 06 gxp
    By nicks98gtp in forum Audio, Security & Visual Electronics
    Last Post: 11-28-2011, 01:45 AM
  3. Installing headunit in 04 GT2 with Monsoon
    By nickleahy23 in forum Audio, Security & Visual Electronics
    Last Post: 08-30-2011, 05:07 PM
  4. Best Aftermarket Headunit?
    By ajc549FF in forum Audio, Security & Visual Electronics
    Last Post: 03-04-2011, 01:01 AM
  5. 2004 monsoon + aftermarket headunit
    By blabo219 in forum Audio, Security & Visual Electronics
    Last Post: 02-03-2010, 03:10 PM
