Thread: Need AMP wiring help!!!!!!! Now with another wire problem
Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
  1. #21 Re: Need AMP wiring help!!!!!!! Now with another wire problem
    ouch lol
    you need to solder a ring connector on the wire, then bolt it down.
  2. #22 Re: Need AMP wiring help!!!!!!! Now with another wire problem
    i know thats the problem i dont have any and all three stereo places ive been to dont have any so im trying to come up with something else
    SMGPFC Member #10
  3. #23 Re: Need AMP wiring help!!!!!!! Now with another wire problem
    GTP Level Member simbah's Avatar
    Lala land
    go to your local car audio shop or radio shack and buy a 4 gauge connector(lug) and attach to wire, don't have a crimper, put lug in vise and insert wire and crush the lug, basicly crimping the lug to the wire.or do this
    http://www.parts-express.com/pe/show...number=095-656
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  4. #24 Re: Need AMP wiring help!!!!!!! Now with another wire problem
    auto parts stores carry these connectors too.
  5. #25 Re: Need AMP wiring help!!!!!!! Now with another wire problem
    advance and autozone does?
    i also havent tryed lowes or homedepot
    SMGPFC Member #10
  6. #26 Re: Need AMP wiring help!!!!!!! Now with another wire problem
    come to think of it, ive been looking up amp stuff myself due to one falling in my lap, and walmart has amp install kits for like 10 bucks. comes with all the power and ground wires. and that remote wire.
  7. #27 Re: Need AMP wiring help!!!!!!! Now with another wire problem
    i have everything hooked up and wired but i just need to attach the ground to car and thats were im stuck at, i might just run to lowes real quick and see what they have(less then a mile away)
    SMGPFC Member #10
  8. #28 Re: Need AMP wiring help!!!!!!! Now with another wire problem
    yes auto zone or pep boys i picked these up for a friends lawn mower battery cables. the old one fell off. soldered new loops on. they had all the common sizes. cost around $5 for a pack of 2.
  9. #29 Re: Need AMP wiring help!!!!!!! Now with another wire problem
    you may get lucky at lowed or the depot, they have pretty good electrical sections.
  10. #30 Re: Need AMP wiring help!!!!!!! Now with another wire problem
    im gonna run to lowes since its across the street and i can walk there, the auto store arn't close, cant hurt since its so close.. be back in 10-15min.lol
    SMGPFC Member #10
  11. #31 Re: Need AMP wiring help!!!!!!! Now with another wire problem
    Jan 2013
    Tolono IL
    i had a long ground wire and hooked it to the tail light it worked so i left it there and ran it under the carpet to the amp
  12. #32 Re: Need AMP wiring help!!!!!!! Now with another wire problem
    Yoga city
    so did you get it done?
  13. #33 Re: Need AMP wiring help!!!!!!! Now with another wire problem
    Yoga city
    Do you have a torch and some solder? best connection is a soldered one. and its easy to do
  14. #34 Re: Need AMP wiring help!!!!!!! Now with another wire problem
    ok so i found some ring lug connectors at lowes(4gauge) and spent 20 mins with a sales guy looking for some crimpers..which hey didnt have and yes im going to solder them
    SMGPFC Member #10
    ... osiris94ej's Avatar
    Sep 2012
    Casper Wyoming
    You need one of these to crimp big wire. Or just solder for simplicity. http://www.kickinbot.com/Project%208...r-switch01.jpg
    Sent using Tapatalk 2 from my GS3.
  16. #36 Re: Need AMP wiring help!!!!!!! Now with another wire problem
    yea defiantly dont have that or a vice, i got 2 so im just gonna try some pliers and alot of muscle, and some solder. im sure ill be able to make something work
    SMGPFC Member #10
  17. #37 Re: Need AMP wiring help!!!!!!! Now with another wire problem
    well that was not easy at all
    i ended up getting close with pliers then using a hammer and a flat head to beat it the rest of the way
    SMGPFC Member #10
  18. #38 Re: Need AMP wiring help!!!!!!! Now with another wire problem
    Yoga city
    Now for a good connection, solder it and tape up some that excess wire.
  19. #39 Re: Need AMP wiring help!!!!!!! Now with another wire problem
    done it this way with the ones i bought for my friend, works like a champ!! i had no vice, used vice grips to hold the loop while heating it up.
  1. led wiring help
    By dpzelenak in forum Audio, Security & Visual Electronics
    Last Post: 03-29-2011, 04:13 PM
  2. wiring help
    By DDPeppa in forum Audio, Security & Visual Electronics
    Last Post: 12-10-2010, 11:19 PM
  3. wiring help
    By grandprixxx94 in forum General Tech Discussion
    Last Post: 09-24-2010, 11:00 AM
  4. Wiring or???
    By GTPJOE90 in forum Audio, Security & Visual Electronics
    Last Post: 09-19-2009, 10:30 PM
  5. Wiring
    By gpgt in forum Audio, Security & Visual Electronics
    Last Post: 03-27-2009, 03:02 PM
