Quote Originally Posted by JTeske88 View Post
im pushing close to 2k watts, set 1750 rms set with dmm, look up the big three and you should be fine. and you will not be going by rms on sub. it will come down to the efficaincy of the amp how much it pulls. what amp you gonna be using? and i have a setup like this, i own the se line before it became the se-x. the x-lines spawn from the re buyout and alotta of it is known to be junk now. if your looking at re, look at the pro line. there pro line is there orignial stuff rebadged. heres a pic of the subs in my trunk.
hmm, Ok so i guess ill continue to look for more subs. well, with the re i planned on using a hifonics, either 1200rms or the closesnt one above 1200 is there isnt a 1200. i was also told to check out sundown. ATM im trying not to spend more then 250 on the subs. i may also be going with that custome trunk enclosure i was shown on ebay. WoofersEtc.com - E-12D2 - Sundown Audio 12" Dual 2-Ohm E Series Subwoofer E12D2
