Thread: gear positioning lights!
Results 1 to 6 of 6
  1. #1 gear positioning lights!
    GT Level Member kyliek23's Avatar
    Feb 2013
    Help! My center counsel lights are burnt out. I have no idea on how to remove the covering for the center counsel and to change the lights.
    2005 Pontiac Grand Prix Base
  2. #2 Re: gear positioning lights!
    St. Louis
    From a search of an older post:
    It's been a while sense I have had mine out. So I'll see if I can remember everything. To start off with, open you armrest and cup holder. Start at the back of the cover by the armrest and with a flat tip screw driver, pop the rear of the cover up. Oh, before I forget, take the storage compartment out of the console, it just slides out. Once the rear of the cover is popped up on each side, you can do the rest by hand by running your fingers down each side and gently pulling up on it. Once all of the cover is popped loose, you may have to pull the shifter back to 1 or 2 to gat it to slide out with ease. There are 2 screws where the compartment was, 2 at the front of the console, and I can't remember if there are 2 around the center. Once you get the top cover out of the way, you should have no problem seeing all the screws. Hope this helps man.
  3. #3 Re: gear positioning lights!
    Feb 2013
    Thank you. My boyfriend told me to ask. Thanks for the help. Ill let you know if it works out good.
  4. #4 Re: gear positioning lights!
    Yoga city
    no no no on the newer style gp you have to pull the whole console, just 4 bolts i believe then you can slide it up enough to get the bulb out pretty easy
  5. #5 Re: gear positioning lights!
    I live here. DirtDog's Avatar
    Jun 2012
    Quote Originally Posted by JTeske88 View Post
    Bulb have to be soldered or does it just plug in?
  6. #6 Re: gear positioning lights!
    Yoga city
    peanut style, will plug in. i ended up just putting an led in mine so i dont have to worry about it.
  1. Dash lights for what gear you are in
    By Freimuth in forum General Tech Discussion
    Last Post: 12-19-2011, 11:44 PM
  2. Gear selector lights
    Last Post: 09-15-2011, 09:13 AM
  3. Positioning of Glasspack
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2010, 06:55 PM
  4. 98 GT Gear Shifter Lights
    By jetscrazy44 in forum Audio, Security & Visual Electronics
    Last Post: 07-23-2010, 12:06 AM
  5. camshaft positioning sensory??
    By goyaoboya8 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2009, 07:52 PM
