Thread: Head unit wiring
Results 1 to 15 of 15
  1. #1 Head unit wiring
    Sep 2012
    St Louis Missouri
    So the wiring for the stock head unit has two plugs with abunch of different wires. The one that came with my head unit is smaller and has way less wires. Instead of cutting off the factory plugs and trying to crimp all the matching wires together, isnt there an adaptor i can buy that will just plug the factory plugs into the new head unit or something? Ive looked all over and cannot find an answer. I dont care about steering wheel controls either as the volume is the only one id use but i never have that hand on the wheel.
    I live here. DirtDog's Avatar
    Jun 2012
    Go to pac audio they have all the harnesses
    Sent from my pager using Morse code. ... .. ... ....
  3. #3 Re: Head unit wiring
    Sep 2012
    St Louis Missouri
  4. #4 Re: Head unit wiring
    Oct 2011
    Oak Grove MN
    do you have the monsoon sound system? if so then you need a different harness that is more expensive.
    Jun 2012
    Yes
  6. #6 Re: Head unit wiring
    Sep 2012
    St Louis Missouri
    No i dont. which one of those that i linked would i use? i just have the base sound system
  7. #7 Re: Head unit wiring
    Oct 2011
    Oak Grove MN
    someone else might be able to chime in but i thought if you had steering wheel controls then you had the monsoon. but in order to retain all the factory things like chimes and onstar you need a harness like this. Metra GMOS-01 GM Factory Integration Adapter Retains OnStar® and factory door chime with aftermarket radio in select GM vehicles at Crutchfield.com
    Jun 2012
    My 04 had steering she'll controls and no moo soon. My current gxp has monsoon
  9. #9 Re: Head unit wiring
    Sep 2012
    St Louis Missouri
    Ok unless monsoon doesn't label anything then I have stock. Which one can I use from my links.
    Jun 2012
    Gmos-01 worked perfect in my non monsoon 04 gp
  11. #11 Re: Head unit wiring
    Sep 2012
    St Louis Missouri
    I said my links
  12. #12 Re: Head unit wiring
    Sep 2012
    St Louis Missouri
    My god anyone please just tell me what the hell one i can use that isnt over 50 dollars.. I dont want steering wheel controls and I have the BASE STOCK audio. I linked two already, can i use any of those two? If not, just link me to one from best buy or walmart or something. PLEASE.
  13. #13 Re: Head unit wiring
    Jun 2012
    when i did mine the only one i found that worked good was the gmos-01. somethings just arent cheap. i tried a 20 dollar one but it messed sh*t up. dic started messing up and gauges went crazy. radio worked though but i took it out the same day i put it in. so they aint that cheap for one tha works
  14. #14 Re: Head unit wiring
    if you just want the plug with marked wires telling you what they are for so you dont have to hack up the factory harness and plug. the best buy pig tail will work. i paid about 20 for one. for another car. you will lose you wheel controls. but you dont seem to care so much, so thats the way id go.
  15. #15 Re: Head unit wiring
    Sep 2012
    St Louis Missouri
    Well guys it doesnt ****ing fit. For some reason my 2000 GM vehicle doesnt qualify as a 1994-2004 GM vehicle, and the metra adapter does not fit into the factory plug, and im pissed off to the max after an hour of crimping with bent crimps and a wasted 30 dollars. (adapter plus crimp)
  1. Wiring AfterMarket Head Unit Bose System
    By BrendanMurphy in forum Audio, Security & Visual Electronics
    Last Post: 12-01-2012, 01:14 PM
  2. OEM Head Unit Wiring
    By blackmoose in forum Audio, Security & Visual Electronics
    Last Post: 06-29-2012, 09:55 PM
  3. Aftermarket Head Unit Wiring Help?
    By beams75 in forum Audio, Security & Visual Electronics
    Last Post: 06-14-2011, 04:52 PM
  4. head unit
    By DDPeppa in forum Audio, Security & Visual Electronics
    Last Post: 06-11-2009, 10:48 PM
