how do you hook up a switch to an amp
For what purpose?
If it is to turn amp on/off then use the remote turn on wire from the headunit.
Yep just put it in the remote wire.
Should work
I have an idea...ya did it wrong.
Try getting the wiring diagram for ur headunit out and making sure the one u hooked it up to was the on wire. If its not working find the wire that supplies the power to radio when u turn ur ignition on and just tap into that.
Sent from my pager using Morse code. ... .. ... ....
