Thread: Switch
Results 1 to 8 of 8
  1. #1 Switch
    SE Level Member Mcbride's Avatar
    Aug 2012
    Iowa
    how do you hook up a switch to an amp
    1999 Pontiac Grand Prix GTP
  2. #2 Re: Switch
    GTP Level Member simbah's Avatar
    Lala land
    For what purpose?
    If it is to turn amp on/off then use the remote turn on wire from the headunit.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  3. #3 Re: Switch
    Yep just put it in the remote wire.
  4. #4 Re: Switch
    SE Level Member Mellsthatguy's Avatar
    Dec 2012
    Michigan
    I just a lil small switch into the remote line and ran it to my center console
  5. #5 Re: Switch
    You solder to wires to the ends of teh switch.
  6. #6 Re: Switch
    Aug 2012
    Iowa
    didnt work
  7. #7 Re: Switch
    Should work
    I live here. DirtDog's Avatar
    Jun 2012
    Quote Originally Posted by Mcbride View Post
    didnt work
    I have an idea...ya did it wrong.
    Try getting the wiring diagram for ur headunit out and making sure the one u hooked it up to was the on wire. If its not working find the wire that supplies the power to radio when u turn ur ignition on and just tap into that.
    Sent from my pager using Morse code. ... .. ... ....
  1. Fan switch help
    By SerenityGTO in forum General Tech Discussion
    Last Post: 10-15-2011, 09:48 PM
  2. Trans switch/ e brake switch
    By Halbs in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2010, 02:57 PM
  3. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
