Thread: 3 way active setup in 97 gtp
Results 1 to 8 of 8
  1. #1 3 way active setup in 97 gtp
    GTX Level Member blakgtp's Avatar
    Sep 2011
    Vancouver
    after my recent purchase of the clarion cz702 headunit, I have been thinking about running a 3 way active front stage. I want to have a 6.5 midbass driver in the doors and midrange in the kick panels. HiVi M3N 3" Aluminum/Magnesium Midbass 297-433
    has any one put a midrange in the kicks? were you able to mount into the metal behind the kick panel, or did you have to fiberglass custom pods?
    my other idea was to try and find an enclosed midrange unit that I could mount on the dash?
    If it is to much hassle to accomplish the 3 way setup, I may just run 2 way active, with a mid and tweeter.
    any input is appreciated
    97 gtp- 3.5 pulley, sd headers, autolite 104's, dhp pcm, hai, 180 t-stat SOLD
    94 skyline- drift slut SOLD
    97 rx7 fd3s twin turbo SOLD
    99 R34 skyline
  2. #2 Re: 3 way active setup in 97 gtp
    GTP Level Member simbah's Avatar
    Lala land
    Those midrange speakers you highlighted may not work. They are 8 ohm speakers and most car receivers don't like 8 ohm speakers(too much impedence(resistance)) so most prefer something like 4 ohm or maybe 2 ohm dependant upon manufacturer.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  3. #3 Re: 3 way active setup in 97 gtp
    I found a $20 5.25" pioneer mid on PE that worked well. Closed back so it didn't need an enclosure.
    Getting speakers on axis does wonders for clarity. Under 15* is best.
  4. #4 Re: 3 way active setup in 97 gtp
    Sep 2011
    Vancouver
    link?
    99 R34 skyline
  5. #5 Re: 3 way active setup in 97 gtp
    search their site.
  6. #6 Re: 3 way active setup in 97 gtp
    Yoga city
    the 8 ohm rating would not be an issue, if say they were 1 ohm yes, lower ohm drives amps harder, but i would take into account when you actually get all speakers wired together on a channel what there final load will be.
  7. #7 Re: 3 way active setup in 97 gtp
    Sep 2011
    Vancouver
    99 R34 skyline
  8. #8 Re: 3 way active setup in 97 gtp
    Sep 2011
    Vancouver
    update
    thinking of getting these for mids: The Madisound Speaker Store
    tweets: The Madisound Speaker Store
    putting them in the doors. I'm wondering if it would be worth it to add a designated midrange and go 3 way, or just run 2way active. i only have a 2 channel amp for front stage right now, so either way I will be buying another amp. I would also like other suggestions for speakers. I'm after a "warm, natural" sound, I absolutely hate bright/ harsh highs.
    99 R34 skyline
  1. Active STL group?
    By Peacher213 in forum Midwest
    Last Post: 02-26-2012, 08:33 PM
  2. Gas guage too active
    By jpalms in forum General Tech Discussion
    Last Post: 01-05-2011, 10:37 PM
  3. Anyone active with a bagged gp?
    By GAFF in forum Brakes/Suspension/Chassis
    Last Post: 04-07-2010, 08:08 PM
  4. Need a favor, some one still active on CGP?
    By GR8racingfool in forum Off Topic Discussion
    Last Post: 04-11-2008, 03:24 PM
