Thread: Took battery out now stereo wont work(Tried taking it to a GM dealership)
Results 1 to 9 of 9
  1. #1 Took battery out now stereo wont work(Tried taking it to a GM dealership)
    Jun 2012
    Chicago IL
    I took the battery out on my 2004 Grand Prix GTP(Monsoon stereo sysetm) and now the stereo wont work. I took it to a local GM dealership to have it reset and they said its not showing any codes or anything when they hook it up. Does anyone have any idea on why that would happen and what my options are? They want to charge me $125 an hour to take out the radio and try and find the problem. Would i be better off just putting in an aftermarket radio or what? Who knew taking out a battery could cause so many problems.
    Any suggestions would be greatly appreciated. Thanks.
  2. #2 Re: Took battery out now stereo wont work(Tried taking it to a GM dealership)
    google unlock codes for your radio. or try you tube, lots of how to unlock a radio vids out there. f the dealer lol
  3. #3 Re: Took battery out now stereo wont work(Tried taking it to a GM dealership)
    Jun 2012
    Chicago IL
    Tried looking up codes for quite a while. On the 2004+ you have to take it to the dealership unless you have the code, which i dont because i bought it used and of course no manual was included. Go figure.
  4. #4 Re: Took battery out now stereo wont work(Tried taking it to a GM dealership)
    theres a few guys here who work at dealerships, maybe one will find this, and with your vin can find it for you. i know how bad having no radio can be.
  5. #5 Re: Took battery out now stereo wont work(Tried taking it to a GM dealership)
    Pennsylvania
    I'd call around and get a better price. Even Sears probably has a TechII.
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    If its locked you need a tech2 to run a radio setup (that's typically what happens when the battery gets pulled) . If it's not working at all ex. No power up, clock won't show up etc. A fuse could be the culprit (pull the radio and make sure the thicker orange wire on the radio has 12v if the fuses are good) . If you have the time you could send it to us we have free estimates. your only responsible for shipping if no problems are found or you decline a repair. We are located in Michigan
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  7. #7 Re: Took battery out now stereo wont work(Tried taking it to a GM dealership)
    Pennsylvania
    Actually, checking the fuse is brilliant. Removing the battery absolutely will not lock up the stereo.
    Oct 2011
    MI
    Quote Originally Posted by SlowNA06 View Post
    Not nessesarly true. I've seen it happen many times before not as common though.. More so on the older radios that you physically have to enter a lock code using the preset buttons. We've got a hotline number for those.
    Typically radio locks because someone swaps a radio into a different vehicle and it doesn't recognize the Vin. Thus a radio setup is required
  9. #9 Re: Took battery out now stereo wont work(Tried taking it to a GM dealership)
    Pennsylvania
    Should have said "should"
  1. 04 GP remote start wont work.
    By Fcukit33 in forum General Tech Discussion
    Last Post: 09-13-2012, 01:52 PM
  2. why wont my park ave pcm work in my top swapped gt??
    By Wisconsingrandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2012, 01:39 AM
  3. a/c wont work and heat wont go to floor PLEASE HELP!!
    By Brett Muszynski in forum Introductions/Noob Questions
    Last Post: 02-10-2012, 05:43 AM
  4. ddm hid fogs wont work
    By gpgt04 in forum Audio, Security & Visual Electronics
    Last Post: 12-20-2010, 12:37 PM
  5. dash lights wont work!!! please help
    By jshuman in forum General Tech Discussion
    Last Post: 02-23-2010, 09:06 PM
