Thread: Speaker wire to RCA help
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
  1. #1 Speaker wire to RCA help
    Jul 2011
    westvirginia
    Bought the car with subs spliced into the stock radio, have recently installed a radio with subwoofer rca jacks, can someone point me in the correct direction to what i need? I looked for simple speaker wire to rca adapters and i found straight adapters, and some kind of hi-low adapters too, what are they for? Thanks
  2. #2 Re: Speaker wire to RCA help
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    just run rca wires from your subwoofer output off the radio to the amp that power the sub and call it a day
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  3. #3 Re: Speaker wire to RCA help
    SWPA
    The RCAs go to the amp, then the speaker wires come out of the amp.
  4. #4 Re: Speaker wire to RCA help
    Jul 2011
    westvirginia
    I thought i had worded the question to which all could understan, but ill further clarify, the subs work now, they are spliced into the factory speaker wires, I want to take the speaker wire running to the subs, unsplice them from the door and rear deck factory speaker wire, add rca jacks and connect them to the radio headunit so i can adjust my subwoofers bass level without effecting the 6x9s and door speakers, hope that helps.
  5. #5 Re: Speaker wire to RCA help
    If I am reading this right they just wired the subs directly to the speakers without an amp.
    You should not run subs directly off any head unit ever just fyi.
    Get an amp and an rca cable that is the best way to do it.
    And the way you want to do it will not work. Those are preamp outputs on the back of the deck.
  6. #6 Re: Speaker wire to RCA help
    SWPA
    Exactly, you will burn subs up if you run them without an amp. Underpowering them is bad.
    You need to run the RCAs to an amp, then the amp to the subs.
  7. #7 Re: Speaker wire to RCA help
    Jul 2011
    westvirginia
    The subs are wired and done properly, 2 12" subs wouldn't even drive runnnig off of stock radioand no amp....the sound inputs are just ran to the factory speaker wire and i wish to unsplice them and connect them to the correct rca preamps...why does no one understand my question idk how else to explain it..
  8. #8 Re: Speaker wire to RCA help
    SWPA
    You cannot use preamps to power speakers. Why do you not understand that?
  9. #9 Re: Speaker wire to RCA help
    Jul 2011
    westvirginia
    I am not powering them with preamps, I have an amp wired to the car battery, my +/- speaker wire dont transmit anything but the sound signal, I wish to split them from the stock wiring and have my subs plug into the back of radio. Then I will have every set of speakers on seperate channels. I have left right(front) left right(rear) and left right(subs). I wsh to connect the speakers to the proper plug in.
    subs solution.jpgHere are two photos of what i am talking about. I wish to unsplice the red(subs) from the rear 6x9's (black)
  10. #10 Re: Speaker wire to RCA help
    Jul 2011
    westvirginia
    Aug 2011
    Kenosha
    Pretty sure I get what your saying. The speaker wires that go to your amp from the rear 6x9's will be disconnected and left alone. Run RCA cables from the rear of your new CD player to the amp powering your subs.
    This way your aftermarket amp will be getting its audio signal from the CD player via RCA cables instead of taking its audio signal from the rear 6x9 speakers. Hope that helps.
    Aug 2011
    Kenosha
    Now that I think about it. What amp are you running. If your running an amp that does not have RCA inputs on it that would explain the confusion. Can you post a pic of the connections that amp has.
  13. #13 Re: Speaker wire to RCA help
    Jul 2011
    westvirginia
    I have an amp with low level inputs and high level outputs, the low level are rca, but high level is a plug...and my high level is just spliced into the factory speaker wire, why couldn't I just unsplice them from the factory wiring, add an rca plug then plug the rca's into the preamp? or would I have to buy two rca adapters and change both ends to rca plugs?
  14. #14 Re: Speaker wire to RCA help
    Jul 2011
    westvirginia
    The proper way would be to run rca all the way, but i do not wish to tear the entire car apart. it was done professionally by previous owners and everything is professionally ran and hidden neatly, It would be easier for me to just change the plugs.
  15. #15 Re: Speaker wire to RCA help
    Jul 2011
    westvirginia
    I was looking at this
    Kicker 09ZISL
    Aug 2011
    Kenosha
    It will make no difference switching the plugs. You need to run rca cables from the head unit to the amp. If your not gonna do it that way id leave it alone.
  17. #17 Re: Speaker wire to RCA help
    Jul 2011
    westvirginia
    If i switch the plugs I will be able to use the adjusts in my radio subwoofer settings
  18. #18 Re: Speaker wire to RCA help
    SWPA
    Do it right. Run RCAs from the headunit to the amp.
  19. #19 Re: Speaker wire to RCA help
    Jul 2011
    westvirginia
    how much cable will i need? approximately, to run from headunit, through glovebox, down door sill then under rear seat? i think thats how its run now.
  20. #20 Re: Speaker wire to RCA help
    SWPA
    I'll be honest, I haven't had a Grand Prix interior apart, but the way I did it in my Stealth and the way I would do it in a Grand Prix is to run it under the center console, then under the carpet, under the rear seat and into the trunk.
  1. How much Speaker Wire and What gauge?
    By GrandPrixGTP1 in forum Audio, Security & Visual Electronics
    Last Post: 02-10-2011, 10:34 PM
  2. How do I replace stock speaker wire?
    By jstevanus in forum Audio, Security & Visual Electronics
    Last Post: 05-09-2010, 10:31 AM
  3. Monsoon Amp Remote Wire and Speaker wiring diagram
    By Thatonepunkrawk in forum Audio, Security & Visual Electronics
    Last Post: 04-18-2009, 07:58 PM
  4. Speaker wire
    By 2000GTP2708 in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 01:49 PM
  5. Running speaker wire....to the doors....help.
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2008, 02:14 PM
