Quote Originally Posted by simbah View Post
From what I am understanding OP wants to splice RCA plugs to both ends of stock speaker wiring, radio end and speaker end, thus creating his own set of RCA cables, am I correct? If so I think that would be more work than just running a new seperate RCA cable from HU to amp........ Just my 2 cents worth. Besides with splicing RCA plug ends to stock wiring you are going to create more places for problems to arise from and by splicing you would lose your rear speakers that the subs are spliced into now.
Nevermind....reread what you're saying and that is correct. Kinda makes it scratch your head, doesnt it? If you want OP, you can run rca's without even getting out of the car. Just run them along your center console. There is plenty of room to just slide the wire under it as you go. When you reach the end of the console, just keep it on the floor. Lift up the bottom of your rear seat and run them into the trunk. You'll have a little bit of wire showing on the hump in the rear but you'll stay warm.
