Thread: Rear 6x9s have no current at all.
Results 1 to 20 of 35
  1. #1 Rear 6x9s have no current at all.
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    So i was in the process of replacing my rear 6x9 s. When i installed the new ones they werent even moving at all.
    So i whip out the multimeter and there is no current of any sort.
    I do have the 4 speaker rear deck.
    I do have subwoofers if that makes a difference.
    Any ideas guys?
  2. #2 Re: Rear 6x9s have no current at all.
    Yoga city
    were you measuring on ac? and the output wont be that great, dont think your gonna see 12 volts or something.
    Mar 2012
    Minneapolis MN
    Quote Originally Posted by Jteske88 View Post
    Yeah i had AC.
    Quite literally there was nothing....
    Its funny, i have them unplugged now and no speakers in those at all, and there is no difference in sound at all.
    So i dont think they ever worked:sly:
  4. #4 Re: Rear 6x9s have no current at all.
    Yoga city
    is your fader to the front? and with the power rating being so low you should only see like 6-7 volts. ohms law FTW!
    Mar 2012
    Minneapolis MN
    Nope my fader is even, i even put it all the way to the back just to see.
    I have an amplifier under the glove box?
    I read somewhere that those only take relatively low Hz like <120 Hz.
    I'll recheck this afternoon.
    But i dont mind the weight reduction. From no seats... RACEKAR
  6. #6 Re: Rear 6x9s have no current at all.
    Yoga city
    you have bose? if you do your amp is in the trunk, if its normal deck its off the deck. never heard of this amp in the dash and i owned a 97 with a stock radio
    Mar 2012
    Minneapolis MN
    Nope i have regular 6 speaker system and there is an amp under the glove box lol
    I swear i have a Frankencar.
    :screwy:
    EDIT: mines a 98 GT.
  8. #8 Re: Rear 6x9s have no current at all.
    Yoga city
    show me this amp and regular 6 speaker? i though it was the bose or non, its ok when i pulled mine apart there was one sub and 2 tweets. i look everywhere for the other speakers wire but it was never installed or hooked up. factory mishap i guess
    Mar 2012
    Minneapolis MN
    If the tweeters count. Then its an 8 speaker system.
    This has info
    http://www.grandprix.net/upgrades/audio.html
  10. #10 Re: Rear 6x9s have no current at all.
    Yoga city
    you got to have a bose then.
    Mar 2012
    Minneapolis MN
    But the speakers aren't labeled bose and they are all AcDelco D:
  12. #12 Re: Rear 6x9s have no current at all.
    Yoga city
    there is no bose on the cover on the door? if not have you acually seen this amp?
    Mar 2012
    Minneapolis MN
    No bose cover lol
    Yes i have lol ill get a pic when i leave schoooll lol
    Mar 2012
    Minneapolis MN
    Here is the amp. This is under/behind the glove box
  15. #15 Re: Rear 6x9s have no current at all.
    Many 97-98 cars have the 8 speaker system with the amp.
    I think when I did mine back when I had my 97, I disconnected the 2 small cycle speakers but I dont remember if I mess with the amp.
  16. #16 Re: Rear 6x9s have no current at all.
    Cleveland Heights, Ohio, United States
    Do a test, route them to the front speaker wires, if they dont work then your subs coulda blew them out. Usually subs blow out weaker rear speakers
    1998 Pontiac Grand Prix GT
    1998 Pontiac Grand Prix GTP
    2008 Buick Lacrosse Super
  17. #17 Re: Rear 6x9s have no current at all.
    Yoga city
    if your looking for original rears pm me other wise you will be doing a small hack job.
    Mar 2012
    Minneapolis MN
    Quote Originally Posted by LowRidinCrew View Post
    But I have a brand new set of kenwoods that I was installing... and those don't work either lol
    Mar 2012
    Minneapolis MN
    Tested speakers on front door wires.
    Speakers work. So its the wiring to the 6x9s...
  20. #20 Re: Rear 6x9s have no current at all.
    Yoga city
    maybe fader is busted, amp is busted, wires messed up,can you try and check output from the amp itself?
  1. 2006 Monsoon system- dead 6x9s
    By MSUvball14 in forum Audio, Security & Visual Electronics
    Last Post: 05-15-2012, 11:20 PM
  2. Where am I at with current setup and what do you think?
    By lightfoot__ in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2011, 12:28 PM
  3. my current sig or this one?
    By BoostJunki3 in forum Off Topic Discussion
    Last Post: 09-07-2009, 12:55 PM
  4. Current setup
    By jarleifv in forum Audio, Security & Visual Electronics
    Last Post: 07-07-2008, 07:27 PM
