Okay, I'm finally home. I got the car vacuumed, washed, and waxed. I checked the oil and other fluids and reset the Mileage thing. I still smell some anit-freeze after I shut the car off when it's hot but can't find anything leaking and she's not overheating or running hot. I may have to run a pressure test on the cooling system later this week. As for the alarm, I removed the panel under the column and couldn't find anything spliced or jumped. I took a bunch of pictures and studied them when I got home and don't see anything resembling the unit above. I will post the pics anyway since you may see something I don't.
Here is all the shots of the column area.....
These are the radio connections that are in where the radio used to be. I'm going to pick up a stock unit this week from Ebay and just replace it.
Aside from all these pics, the only thing I found which is NOT related to the alarm is this plug in the engine bay which is not connected to anything. Maybe someone knows where it goes or what it does. It looks like a weatherized plug so I don't know why it's not going to anything???
So I guess I'll just get the remote FOBS to work and have the guy install a new alarm system in it and call it a day. Then I'll disconnect that annoying Security light bulb on the dash. Thanks again for looking.
