Thread: 02 GP GT Coupe Security Question???
Results 1 to 20 of 25
  1. #1 Re: 02 GP GT Coupe Security Question???
    GT Level Member 02GPinNY's Avatar
    Aug 2012
    Port Chester, NY
    Post a pick of the wires under your steering column and I'll let you know if there's anything aftermarket under there.
    Yes, definitely. I don't want to touch anything I don't know. God forbid I disable the car or something. I have the camera charged up and ready to go. I'll take plenty of pics. Thanks Keith. Have a great evening!
    2002 GT Red, Stock, Work In Progress..........
  2. #2 Re: 02 GP GT Coupe Security Question???
    Aug 2012
    Port Chester, NY
    Okay, I'm finally home. I got the car vacuumed, washed, and waxed. I checked the oil and other fluids and reset the Mileage thing. I still smell some anit-freeze after I shut the car off when it's hot but can't find anything leaking and she's not overheating or running hot. I may have to run a pressure test on the cooling system later this week. As for the alarm, I removed the panel under the column and couldn't find anything spliced or jumped. I took a bunch of pictures and studied them when I got home and don't see anything resembling the unit above. I will post the pics anyway since you may see something I don't.
    Here is all the shots of the column area.....
    These are the radio connections that are in where the radio used to be. I'm going to pick up a stock unit this week from Ebay and just replace it.
    Aside from all these pics, the only thing I found which is NOT related to the alarm is this plug in the engine bay which is not connected to anything. Maybe someone knows where it goes or what it does. It looks like a weatherized plug so I don't know why it's not going to anything???
    So I guess I'll just get the remote FOBS to work and have the guy install a new alarm system in it and call it a day. Then I'll disconnect that annoying Security light bulb on the dash. Thanks again for looking.
  3. #3 Re: 02 GP GT Coupe Security Question???
    Aug 2012
    Port Chester, NY
    While cleaning out the car I found this "antenna" looking thing in the trunk under the spare tire. Does anyone recognize what this might be??? It has 3M Tape in four locations which makes me believe that it attaches to the glass somewhere. I'm just trying to figure out what it's for. Thanks.
  1. 1999 gtp coupe rocker panels rotted out?? Question on replacement parts
    By robbiegtp in forum General Tech Discussion
    Last Post: 05-31-2012, 09:33 PM
  2. 01 Gp gt vs 07 or 08 altima coupe 2.5s vs infiniti g35 coupe
    By grandprixgt in forum Track Sessions and Kills
    Last Post: 02-26-2012, 05:56 PM
  3. Seat question 1997 GP Coupe and vette
    By Logan541 in forum General Tech Discussion
    Last Post: 09-05-2011, 08:41 AM
  4. security system question
    By bkatrenak in forum Audio, Security & Visual Electronics
    Last Post: 03-01-2011, 05:37 PM
  5. Security
    By Bob8205 in forum Introductions/Noob Questions
    Last Post: 08-31-2009, 06:43 PM
