Thread: wacky gas gauge
Results 1 to 10 of 10
  1. #1 wacky gas gauge
    Jun 2012
    illinios
    gas gauge moves all over from full to empty even when car is sitting still any idea to fix ? ground maybe? float?
  2. #2 Re: wacky gas gauge
    Jan 2012
    Philadelphia
    what year is the car?
  3. #3 Re: wacky gas gauge
    GTX Level Member blackflag's Avatar
    Virginia
    probably a bad fuel sender.
  4. #4 Re: wacky gas gauge
    Fuel level sensor. Its not even a sensor, its just an piece of plastic with some fingers on it that run across a circut board and that sends the info the computer. The fingers wear off and cause the wacky gas gauge.
    Search the problem on here and you'll find tons of info. Also search on youtube "bonneville fuel level sensor replacement" and watch the vids.
  5. #5 Re: wacky gas gauge
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    I second this. I had a very similar problem and the dealer told me to replace the entire pump and sender unit. I said no thank you and tried what that guy did on the video. I was amazed at how easy it was, just buy the exact piece and follow the video, it wasn't difficult and took me less than an hour. It has been working for about 4 years now. Best of luck.
    Infinity all around.
  6. #6 Re: wacky gas gauge
    Virginia
    Nice!
    Yeah man. Let me know if you have any questions!
  8. #8 Re: wacky gas gauge
    Jul 2012
    augusta, ks.
    Quote Originally Posted by chamilton89 View Post
    I replaced the entire pump with a good used one and the gauge is still not working. What should I look at now? I talked to a mechanic and he suggested that maybe I might have a faulty cluster. Any comments?
    Um... Did u need to replace the entire pump? Anyway, what's done is done. It could be a bad cluster, but of that's the case it may be more trouble than it's worth. Also, however unlikely, the second pump could have a bad pickup as well. Not sure where you should go from here though.
  10. #10 Re: wacky gas gauge
    Nov 2009
    Brooklyn NY
    try looking at the MAP sensor... that also has a lot to do with the fuel gauge for some reason.
  1. Wacky expressions
    By Andrew_99GTP in forum Off Topic Discussion
    Last Post: 01-07-2008, 09:28 PM
