Thread: tach signal wire behind the dash?
Results 1 to 10 of 10
  1. #1 tach signal wire behind the dash?
    Donating Users kind153's Avatar
    Pittsburg, KS
    98 gt.. I thought there was a wire behind the cluster that I can tap into for viper 5701. any help would be appreciated.
    thanks,
  2. #2 Re: tach signal wire behind the dash?
    Apr 2009
    Fort Worth TX
    I don't know about the Viper but I think the cluster tach is driven by a stepper motor via the PCM.
  3. #3 Re: tach signal wire behind the dash?
    Pittsburg, KS
    thanks! according to the install manual, it needs 1v~6v AC signal.
    so I really have to go through the firewall just for the tach wire?
  4. #4 Re: tach signal wire behind the dash?
    Apr 2009
    Fort Worth TX
    Some after market tachs are driven by the HB CKP (crankshaft position sensor). I believe that signal goes to the ICM. If I'm right then yes you have to wire into that signal.
    I think this is how they get a RPM signal when your car is on a dyno.
    Maybe someone else knows better and they'll chime in.
  5. #5 Re: tach signal wire behind the dash?
    Pittsburg, KS
    well.. my problem is, the module is set to a mode called virtual tach, which seems to sense the voltage before and after to decide whether the engine is running.
    It works ok most of the time, but it seems to die, then restart especially more often when A/C is on. So I was trying to see if feeding the tach signal will solve the problem.
  6. #6 Re: tach signal wire behind the dash?
    Houston
    Change to voltage sense and forget about the virtual tach, and physical tach wire. Its in menu 3, option 2
  7. #7 Re: tach signal wire behind the dash?
    Pittsburg, KS
    wait.....voltage and virtual tach is different????? I'm confused.
    3-2 ENGINE CHECKING VIRTUAL TACH: (1) When set to “virtual tach” the remote
    start will monitor the cranking voltage of the vehicle and set that voltage
    as a reference point. Fifteen seconds after the crank output sequence the remote
    start checks the voltage again to determine if the vehicle is running.
    When set to voltage, the unit cranks the starter for the programmed time and
    then attempts to sense that the engine is running by detecting an increase in
    voltage. When set to Tachometer, the unit references the learned tach signal to
    disengage the starter. In addition it will monitor the RPM and shut down if the
    engine RPM is too high or too low.
    Note: The tach wire must be connected and programmed for the manual transmission
    mode to work.
    apparently!??
  8. #8 Re: tach signal wire behind the dash?
    Apr 2009
    Fort Worth TX
    So this thing is a remote starter system?
    Looks like the system senses if motor has started two ways:
    1. Increased system voltage from the alternator
    2. Increased engine RPM
    Keith is saying let the system work with #1 and forget about the virtual tach.
  9. #9 Re: tach signal wire behind the dash?
    Houston
    Quote Originally Posted by kind153 View Post
    mode to work.
    apparently!??
    Yes. If you set it to voltage sense you should be fine. If it still shuts down, you need to wait for it to shut down and check the LED blinks for the shutdown diagnostics. That will point you to the cause. I had issues with the virtual tach as well. Just switched to voltage sense and that was that.
    Basically just open the door, then turn the key to on then off. The hold the valet button until you hear a chirp from the siren. Keep holding the valet button until you hear 3 chirps (3rd menu). Release the button. Then press the valet button 3 times and hold it on the 3rd push. You should hear 2 chirps (option 2). You should only have to push the lock button on the remote once if you are currently on Virtual Tach. You should hear 2 chips and you can release the valet button.
  10. #10 Re: tach signal wire behind the dash?
    Pittsburg, KS
    got it - I changed it to voltage and so far so good. I've been thinking, for last 3 years, that virtual tach was the voltage sensing.
    anyway, thanks Keith!!
  1. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  2. Dyno Tach Signal Hunt
    By SlowNA06 in forum General Tech Discussion
    Last Post: 01-04-2011, 06:34 PM
  3. Few ?'s. What gives tach signal, and TCC solenoid ?'s
    By 03grandprix in forum General Tech Discussion
    Last Post: 10-18-2010, 08:06 AM
  4. Right signal light flashes fast, left signal flashes normal speed?
    By nboylie in forum General Tech Discussion
    Last Post: 11-23-2009, 06:38 PM
