Quote Originally Posted by Skoll View Post
I pretty much just popped the dash plate off, it was pretty easy since the previous owner obviously didn't care for the car, it was a bit loose for me. All you do from there is take off the faceplate of the DiC, then unscrew both sides, I forget which size but it's a pretty small hex screw, and viola. You'll be presented with three bulbs. I believe there is a more accurate, in-depth How-To on the forums. Just use the search function since this is a pretty common issue.
Thank you kindly Skoll.
