Thread: HID issue
Results 1 to 10 of 10
  1. #1 HID issue
    Dec 2012
    Hamilton,Ontario
    So I bought this car (97 gtp) that has HID ballasts and bulbs installed. They seem to be working fine but I think there may be a power issue. While i'm driving I notice alot of subtle flickering with the interior lights and dash lights, but when I park and turn the headlights off it goes away. Any ideas where I can start?
  2. #2 Re: HID issue
    GTP Level Member buickman104's Avatar
    NYC
    Are you running power from the battery or tapping into the headlight wiring for power?
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  3. #3 Re: HID issue
    Dec 2012
    Hamilton,Ontario
    That is a good question, I do believe it's from the headlight harness, a plug and play version, but i'd have to check tomorrow in the light.
  4. #4 Re: HID issue
    Dec 2012
    Hamilton,Ontario
    These ballasts are plugged into the stock headlight socket for power. I also notice that after driving if I park, the lights will go screwy; alternating from one to the other and sometimes the drivers side goes out completely. Could this also be a bad ground? I read a "how to" and it said to disable DRL and security flashes, could this have buggered up the bulbs or ballasts?
  5. #5 Re: HID issue
    NYC
    Sounds like you need to buy a heavy duty harness. Are your ballasts 35w or 55w? If you buy a harness i would suggest you pick one up from theretrofitsource.com well worth it in quality wiring.
  6. #6 Re: HID issue
    Dec 2012
    Hamilton,Ontario
    They're 35w ballasts. And what do these harnesses you're referring to do?
  7. #7 Re: HID issue
    Dec 2012
    Hamilton,Ontario
    Thanks for the replies, upon inspection, these are slim ballasts with 35w ignitors. They're wired fully into the stock socket strictly for signal, ground and power. I think I may swap these out and put stock headlights back in.
  8. #8 Re: HID issue
    Nov 2012
    Madison
    Quote Originally Posted by Adasm View Post
    that would be the easiest way to trouble shoot if it is the HID set-up or not..then go from there..grab some 9006s or borrow some just to see
  9. #9 Re: HID issue
    Dec 2012
    Hamilton,Ontario
    Quote Originally Posted by spazzz View Post
    Thats what I was thinking. I have the original bulbs in a box and the HID kit seems pretty easy to swap in or out.
  10. #10 Re: HID issue
    Dec 2012
    Hamilton,Ontario
    This is pretty much exactly what i've got attached to each headlight.
  1. l67 GTP issue
    By mschooley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2012, 06:44 PM
  2. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
  3. 05 issue
    By gtpinsc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-13-2011, 08:21 AM
  4. 97 key issue
    By Jay7199 in forum General Tech Discussion
    Last Post: 02-20-2011, 07:13 PM
  5. another kr issue
    Last Post: 02-24-2009, 12:30 PM
