Thread: display is dim and cannot be seen unless direct light is on it
Results 1 to 5 of 5
  1. #1 display is dim and cannot be seen unless direct light is on it
    Apr 2012
    Manorville, Ny
    So just recently I was driving on the expressway doing around 75 & hit a small bump and at that speed it felt like a big one. It wasn't that big of a deal but when I looked at my display that shows your mpg & oil life I could not see it at all it was completely dim. When the sunlight hits it I can barley see what it says, has anyone else had this problem & how do I fix this?
    The car is a 1998 Grand Prix Gtp 4 door with 119k on it.
  2. #2 Re: display is dim and cannot be seen unless direct light is on it
    London Ont, Canada
    are you referring to the Heads Up display/HUD???
    if so, it probably popped a spring, easy fix, look around for HUD repair threads.
  3. #3 Re: display is dim and cannot be seen unless direct light is on it
    Ocala, FL
    Mpg, and oil life.. He's talking about the DIC - digital information center.
    Sounds like you have a bulb loose, or burnt out. There's a few threads on here about removing the DIC and replacing the bulbs. Could also be a connector, either way if you pull the dash trim and remove the DIC you'll get it figured out.
    Edit, check this link:
    http://www.clubgp.com/newforum/tm.as...heck=675549179
  4. #4 Re: display is dim and cannot be seen unless direct light is on it
    Smack the dash hard and see if it comes back.
  5. #5 Re: display is dim and cannot be seen unless direct light is on it
    Apr 2012
    Manorville, Ny
    Haha I already tryed that a few times, didn't help though
  1. Direct injection
    By dert in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2011, 03:28 PM
  2. Catalytic Conveter direct fit
    By Manish1661 in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2009, 11:10 PM
  3. Light bulb in radio display question
    By singularity in forum General Tech Discussion
    Last Post: 08-31-2009, 09:30 AM
