Thread: Electrical upgrade again!!
Results 1 to 9 of 9
  1. #1 Electrical upgrade again!!
    Jersey
    Hey guys. I know people will get tired of hearing about the big 3 and stuff but i need to understand it lol. I have a 97 gp se. I just brought 20 ft of power and ground wire. Im gonna skip the power wire for the moment and just do the grounds. I wanted to know where are all the ground locations under the hood so i can get this thing started. Pics would help but everybody has other things to do lol...thanks
  2. #2 Re: Electrical upgrade again!!
    SE Level Member BKA05GT's Avatar
    May 2008
    Grand Ledge, Mi
    Ill try to get you some good pictures as soon as im free. I did this on my 05. I also ended up needing a 350 amp alternator, as the big 3 was no where near enough for my set-up =(
  3. #3 Re: Electrical upgrade again!!
    Jersey
    Thanks bro. You had to get a new alternator!? Damn, you must be pushing crazy watts !!!
  4. #4 Re: Electrical upgrade again!!
    Yoga city
    simple battery - to engine block, battery - to frame, battery + to starter +, battery + to fuse box +, altrenator + to battery + or fuse box. done maybe 10 feet
  5. #5 Re: Electrical upgrade again!!
    Yoga city
    what you running to need that much, cause if my math is good thats enough for about 4200 watts at 12 volt or roughly 5,000watts at running
    Quote Originally Posted by BKA05GT View Post
  6. #6 Re: Electrical upgrade again!!
    Jersey
    Im running 2 12" sony subs (lmao), 1100 watt 2 channel amp (probably running half of that), and a eclipse 800 watt 4 channel amp !!! Do you have pics of yours jteske88??
  7. #7 Re: Electrical upgrade again!!
    Jersey
    I brought extra wire just in case i make a mistake lol
  8. #8 Re: Electrical upgrade again!!
    Yoga city
    here my current setup,
  9. #9 Re: Electrical upgrade again!!
    Yoga city
    with your amount of power gotta be a bad ground on your system. no way in hell you should be killing your electrical.
  1. Headlight and FogLight Upgrade (to upgrade to HID or not?) Please Help???
    By Michigan04GrandPrix in forum Visual/Body Modifications
    Last Post: 04-20-2012, 12:53 PM
  2. electrical
    By pontiac fixer in forum General Tech Discussion
    Last Post: 03-21-2012, 10:10 AM
  3. Big 3 Electrical upgrade
    By wvprix in forum Audio, Security & Visual Electronics
    Last Post: 05-11-2011, 11:46 PM
  4. Electrical
    By 97gp97 in forum General Tech Discussion
    Last Post: 11-10-2008, 04:02 PM
  5. Electrical (HELP)
    By tooez in forum General Tech Discussion
    Last Post: 05-24-2008, 07:28 PM
