Thread: Disable keyless light flashing?
Results 1 to 7 of 7
  1. #1 Disable keyless light flashing?
    GTP Level Member apierce1289's Avatar
    United States
    Is there a way to disable the headlights from flashing with the keyless entry? But still keep the horn noise so you know its locked. It would be cool to disable the lights from flashing. Disable headlights only if possible, I'd still like blinkers to flash so if its dark I know it received the signal from the remote. I can cut and solder the harness if need be. Just need guidance. Need to know if I need resistors or what not to do this etc...
    Sent from my XT912 using Tapatalk 2
    Gremlins always seem to show up in pairs, or groups of three with our cars...
  2. #2 Re: Disable keyless light flashing?
    GTP Level Member buickman104's Avatar
    NYC
    You can program it. I can look it up for you on my owners manual when i get home.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  3. #3 Re: Disable keyless light flashing?
    Dec 2008
    Lawndale, CA
    What year is the car?
    United States
    Quote Originally Posted by The Guz View Post
    2002
  5. #5 Re: Disable keyless light flashing?
    Dec 2008
    Lawndale, CA
    You can do this to have only the corners flash. If not then you have to go into the programming mode to disable the flashing lights. You will also lose the horn if you do that.
    ClubGP:
  6. #6 Re: Disable keyless light flashing?
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by apierce1289 View Post
    An easy option.....
    Alarm_Headlamp_Flash
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
    United States
    Nope I like the auto on feature lol.
  1. Replies: 5
    Last Post: 10-04-2012, 02:40 PM
  2. Engine light flashing never seen that before?
    By h0wl0ngcanitbe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2011, 02:14 PM
  3. Security light flashing
    By Bunty in forum General Tech Discussion
    Last Post: 12-22-2010, 04:38 PM
  4. Security Light Flashing
    By Pickup Man in forum Audio, Security & Visual Electronics
    Last Post: 11-13-2010, 06:29 PM
  5. Flashing security light??
    By 91z in forum General Tech Discussion
    Last Post: 03-03-2010, 03:22 PM
