Thread: Headlamp relay issue 07 GXP
Results 1 to 4 of 4
  1. #1 Headlamp relay issue 07 GXP
    SE Level Member BlauGXP's Avatar
    Springfield, MO
    Hey guys, I did some searching but could not find anything similar. I have an 07 GXP that I put an aftermarket DDM HID kit on right after I bought it in 10/2010. Then, about 4 months ago, my headlights just stopped turning on. Found out it was the headlamp relay thats located in the fuse panel right behind the battery and it had failed. I replaced that and all was well for a while, until last night when it fried again in spectacular fashion. This time the headlights wouldn't turn off and I found that the relay literally smoking it was so hot! I got another relay from autozone (thank God for lifetime warranties) but clearly this isnt going to work long-term. Is the only solution to buy an aftermarket HID relay kit? The DDM hid kit I have currently just plugs right in to the factory connections. Anyone else have this problem/any other solutions?
    07 GXP, Imperial Blue. Stock
    04.5 Jetta GLI, 14.1@98.5mph
  2. #2 Re: Headlamp relay issue 07 GXP
    Brightening up your day. Koniig's Avatar
    Jun 2010
    Illinois.
    This is where you have to be careful when not running an actual harness. I have an 07 GXP also and I would without a doubt recommend a harness because there is always the possibility that you could burn up the factory wiring. Your car might be showing signs of this already from what I understand.
  3. #3 Re: Headlamp relay issue 07 GXP
    Springfield, MO
    Damn, that sucks! Does the harness cause any sort of lamp-out warning to come on that you know of?
  4. #4 Re: Headlamp relay issue 07 GXP
    Jun 2010
    Illinois.
    Not on our cars, you should be good.
    I would go like something like this:
    Low Beam: 9006/HB4 - Relay Harnesses from The Retrofit Source Inc
  1. Headlamp adjuster fix: [*]
    By BackInBlack in forum How To Write-Ups/Tech Tips
    Last Post: 05-12-2015, 09:31 PM
  2. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  3. No power to fuel pump relay from PCM? *Update issue resolved*
    By txslow6 in forum General Tech Discussion
    Last Post: 08-10-2011, 09:23 AM
  4. Headlamp out warning
    By gemax in forum General Tech Discussion
    Last Post: 06-24-2011, 12:08 PM
  5. headlamp questions
    By Tagartine in forum Visual/Body Modifications
    Last Post: 05-28-2010, 01:08 PM
