Thread: Sub Help
Results 1 to 7 of 7
  1. #1 Sub Help
    Stockbridge
    Does anyone know how to stop the rattleing from the rear speaker column and light/glasses head column because my subs shake it to death.
  2. #2 Re: Sub Help
    Jun 2011
    Detroit, MI
    If it excessive I would make sure all the nuts are tight and to use sound deadener in these areas.
    iLoveSpade
  3. #3 Re: Sub Help
    Houston
    Take off the deck cover and fire the subs. Locate the rattle(s), tighten and/or sound deaden necessary locations.
  4. #4 Re: Sub Help
    GTP Level Member
    springfield IL
    Turn ur gain down! :-).
  5. #5 Re: Sub Help
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    got 8 layers of seal n peal on mine think i'm getting rattle again....
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  6. #6 Re: Sub Help
    Feb 2009
    Virginia
    Quote Originally Posted by 1LoudGrandPrix View Post
    Adding more layers significantly DECREASES any measurable gains. If you don't want rattle...find where the parts are vibrating together and stop it at that point. Resonating panels are different, that's where you throw on a sheet of second skin/seal peal/dynamat(whatever product you want). Covering 25% of the panel lowers 90% of the resonation to a lower frequency. Weight is your friend when killing out resonating panels. Vibrations between two objects is something different though.
    I have a feeling there's another purpose for your setup I'm just making sure others know!
    11 is louder than 10!
  7. #7 Re: Sub Help
    Sep 2011
    Arkansas
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
