Quote Originally Posted by Dipchef View Post
Hey Infinity take it from someonw who has actually repalced every part of the monsoon system....its well worth it to run all new wiring how ever that center channel speaker up from is what completes the sound stage IMO. I actually kept the monsoon amp and im only using it for that cente channel speaker. it would take you literally a days time if planned out properlly and also if u have a clear scheduel....but it is worth it
Thanks for the info! Can I tap your brain on how you have things wired? Initial thoughts are that you can you just leave all the existing stock wiring in place along with the Monsoon amp and then get a harness for the HU to power what amounts to the center speaker and then run a second amp off of the RCA connections to feed the new speaker wiring. I'm not sure if that would work or not.
