you need to install a relay, i had this problem when i first got my projectors with HIDs install the really and you should be good to go, and as for the interior lights, it might be you settings, if you look in your owners manual, you find a section under security options, you'll most likely want to set if to the 4 chime option (full security, lights flashes and the whole shabang- should be golden from there
