Thread: brights indicator on after low beam hid install
Results 1 to 14 of 14
jteske88 brights indicator on after... 02-11-2012, 08:37 AM
BoostenGTP Re: brights indicator on... 02-11-2012, 08:39 AM
jteske88 Re: brights indicator on... 02-11-2012, 08:42 AM
Curt7 Re: brights indicator on... 02-11-2012, 06:28 PM
dpzelenak Re: brights indicator on... 02-11-2012, 06:33 PM
dpzelenak Re: brights indicator on... 02-11-2012, 06:37 PM
Curt7 Re: brights indicator on... 02-11-2012, 07:15 PM
jteske88 Re: brights indicator on... 02-14-2012, 06:12 AM
zada230 Re: brights indicator on... 02-21-2012, 02:41 AM
dpzelenak Re: brights indicator on... 02-21-2012, 08:09 AM
jteske88 Re: brights indicator on... 02-21-2012, 08:13 AM
dpzelenak Re: brights indicator on... 02-21-2012, 08:17 AM
jteske88 Re: brights indicator on... 02-21-2012, 08:22 AM
dpzelenak Re: brights indicator on... 02-21-2012, 08:25 AM
  1. #1 brights indicator on after low beam hid install
    Yoga city
    so ive come to realize that some how the car knows there is no brights hooked up. my qeustion is the low beam back feeds on the bright side? if it does can i measure resistance in the bulb to determine wich resitor to use? or will this be a bigger issue. sry but i cant find diddley squat searching on this. and if this isnt correct place for this move please mods. thankyou guys in advance for any help
  2. #2 Re: brights indicator on after low beam hid install
    Resident ZZP Leg Humper BoostenGTP's Avatar
    Grand Rapids, MI
    Do you have a harness installed with the HID's? They aren't getting enough voltage if the high beam indicator is on.
    2014 Mustang GT Sterling Grey 5.0 Track Package NEW 2000 Grand Prix GTP Red SOLD
    2000 Mustang GT LTR SOLD 2000 Grand Prix GTP Silvermist SOLD
  3. #3 Re: brights indicator on after low beam hid install
    Yoga city
    yes and i tried both its on regardless, and it will come on if i turn parking lights on. i may mention this is a single low beam kit so there is no contact to the high beam circuit.
  4. #4 Re: brights indicator on after low beam hid install
    SE Level Member Curt7's Avatar
    Jul 2011
    Ontario
    Not sure if this applies to you but i had the same problem. When i purchased my hid kit (lows AND highs) i installed it myself. My high beam light on the dash was half showing up and i couldnt change from lows to highs and back. Turns out after lots of research 9007 hids (our lights) are the same kit used with 9004 kits because the harness was the same. The only thing that needs to be changed is on pin on the connector needs to be swapped with another. Its usually the center pin on the hid main harness that needs to be swapped with either the left or right pin. I found the right way to do mine by getting 3 loose pieces of wire and just sticking it in each harness changes the connections. Once if found the right set up i just pushed the pins out (easier said than done) swapped their positions and hooked it back up. Good to go
    2003 Grand Prix GT
  5. #5 Re: brights indicator on after low beam hid install
    Curt, that wont work because the connector only has 2 wires in it, power and ground.
    SMGPFC Member #10
  6. #6 Re: brights indicator on after low beam hid install
    Ive had this problem for almost a year now and i cant figure it out. Ive made lots of threads about it and nothing has changed
    Heres the main thread i made, see if this matches what you are experiencing
    http://www.grandprixforums.net/hid-problem-45841.html
    SMGPFC Member #10
  7. #7 Re: brights indicator on after low beam hid install
    Jul 2011
    Ontario
    Alright, my connector had 3. It looked similar to this:
    Except the other piece that connects to this is the side i swapped the pins. The side that comes with the hids. If im wrong, im wrong though! Just did mine last week.
    2003 Grand Prix GT
  8. #8 Re: brights indicator on after low beam hid install
    Yoga city
    ok well i get off early today and im willing to bet it has something to do with the lack of conection between the high and low side of the bulb, if you look at a bulb you can see that the filaments are on the same path so there has to be some resistance there, imma ohm out a light bulb and buy a resistor to see if i can do something for this community. i know tons of ppl would like to get rid of the damn light! espcially in the hud, the dim indicator is ok but it bright on my hud. but do any of you think that my idea is at least possible?
  9. #9 Re: brights indicator on after low beam hid install
    usa
    if you have a harness installed with the vvme HID's? They aren't getting enough voltage if the high beam indicator is on.
  10. #10 Re: brights indicator on after low beam hid install
    the light was on when i had the harness on or off, it didnt care about the harness
    FYI i have a harness for the lows and fogs
    SMGPFC Member #10
  11. #11 Re: brights indicator on after low beam hid install
    Yoga city
    im gonna have time to trouble shoot and fab up a resistor of some sort. i know i can figure this out and help everyone.
  12. #12 Re: brights indicator on after low beam hid install
    i tired that, i even put a resistor in place of the high beam bulb and that did work, the only way i saw to do something with the bulb itself and for that you would have to cut the holder that the bulb sits in.
    but either way i hope you have better luck then i did, good luck
    SMGPFC Member #10
  13. #13 Re: brights indicator on after low beam hid install
    Yoga city
    well did you measure resistance on the bulb? there gotta be a way, cause once you pull the bulbs the indicator acts wierd so, imma work a miracle after i lay my carpet today.
  14. #14 Re: brights indicator on after low beam hid install
    not on the bulb but i found almost 5v on the high beam side so i put a resistor in place of the bulb to take up that voltage. but it didnt like that
    i hope you can figure it out i gave up after awhile, you will be loved for ever if you fix it lol..
    SMGPFC Member #10
  1. high beam indicator
    By BoostnBlackGTP in forum Visual/Body Modifications
    Last Post: 01-28-2011, 05:56 PM
  2. Need High Beam, Low Beam, Fog wiring help...
    By TuKoolGTP in forum General Tech Discussion
    Last Post: 12-29-2009, 12:57 PM
  3. High Beam Indicator light stays on
    By mike4567 in forum General Tech Discussion
    Last Post: 08-07-2009, 08:05 PM
  4. Driving with Brights On ?!?
    By John02Hawk in forum The Rant Forum
    Last Post: 07-26-2009, 11:35 AM
  5. New HIDs installed and High Beam/Low Beam issue CORRECTED!!! Woot!
    By GeddyLee in forum General Tech Discussion
    Last Post: 01-29-2009, 07:26 PM
