Thread: brights indicator on after low beam hid install
Results 1 to 14 of 14
  1. #1 Re: brights indicator on after low beam hid install
    Yoga city
    yes and i tried both its on regardless, and it will come on if i turn parking lights on. i may mention this is a single low beam kit so there is no contact to the high beam circuit.
  2. #2 Re: brights indicator on after low beam hid install
    SE Level Member Curt7's Avatar
    Jul 2011
    Ontario
    Not sure if this applies to you but i had the same problem. When i purchased my hid kit (lows AND highs) i installed it myself. My high beam light on the dash was half showing up and i couldnt change from lows to highs and back. Turns out after lots of research 9007 hids (our lights) are the same kit used with 9004 kits because the harness was the same. The only thing that needs to be changed is on pin on the connector needs to be swapped with another. Its usually the center pin on the hid main harness that needs to be swapped with either the left or right pin. I found the right way to do mine by getting 3 loose pieces of wire and just sticking it in each harness changes the connections. Once if found the right set up i just pushed the pins out (easier said than done) swapped their positions and hooked it back up. Good to go
    2003 Grand Prix GT
  1. high beam indicator
    By BoostnBlackGTP in forum Visual/Body Modifications
    Last Post: 01-28-2011, 05:56 PM
  2. Need High Beam, Low Beam, Fog wiring help...
    By TuKoolGTP in forum General Tech Discussion
    Last Post: 12-29-2009, 12:57 PM
  3. High Beam Indicator light stays on
    By mike4567 in forum General Tech Discussion
    Last Post: 08-07-2009, 08:05 PM
  4. Driving with Brights On ?!?
    By John02Hawk in forum The Rant Forum
    Last Post: 07-26-2009, 11:35 AM
  5. New HIDs installed and High Beam/Low Beam issue CORRECTED!!! Woot!
    By GeddyLee in forum General Tech Discussion
    Last Post: 01-29-2009, 07:26 PM
